[RT-AC87U] Enable/Disable a specific router LAN port via shell command
GSpock
is there a way to enable/disable a specific LAN port via a shell command/script ?
(yes, I feel sometimes too lazy to manually remove/replug the cable ... )
Thanks,
GS
