RT-AC87U has started randomly dropping and reconnecting in the past day
dougiejones
As the title says, my router has curiously developed this problem. Thought it was the ISP so I called them up, but they swear it's the router or modem. No idea why it might be doing this.
Some other info:
-Connection is wired
-Never had any issues like this before now
-Most of the time when this happens, the bars on the router all show blue and the router hub/menu shows it as connected
-One of two router/modem setups in the house. The other one has been working fine and has zero problems
Here's a log, if it does any good:
Apr 18 20:47:42 rc_service: ip-up 1930:notify_rc start_firewall
Apr 18 20:47:43 miniupnpd[2002]: shutting down MiniUPnPd
Apr 18 20:47:43 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 20:47:43 miniupnpd[2063]: version 1.9 started
Apr 18 20:47:43 miniupnpd[2063]: HTTP listening on port 46725
Apr 18 20:47:43 miniupnpd[2063]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:00:34 disk_monitor: Got SIGALRM...
Apr 18 21:27:47 rc_service: httpd 276:notify_rc start_autodet
Apr 18 21:27:50 rc_service: httpd 276:notify_rc restart_wan_if 0
Apr 18 21:27:51 rc_service: httpd 276:notify_rc start_webs_update
Apr 18 21:27:51 rc_service: waitting "restart_wan_if 0" via httpd ...
Apr 18 21:27:52 kernel: Attempt to kill tasklet from interrupt
Apr 18 21:27:54 wan: [wan0_hwaddr] == [AC:9E:17:49:63:90]
Apr 18 21:27:54 wan: [deconfig] udhcpc done[286]
Apr 18 21:27:55 pppd[2630]: pppd 2.4.7 started by admin, uid 0
Apr 18 21:27:55 pppd[2630]: Connected to 00:00:5e:00:01:51 via interface eth0
Apr 18 21:27:55 pppd[2630]: Connect: ppp0 <--> eth0
Apr 18 21:27:58 pppd[2630]: PAP authentication failed
Apr 18 21:27:59 pppd[2630]: Connection terminated.
Apr 18 21:28:07 WAN Connection: Failed to authenticate ourselves to peer.
Apr 18 21:28:08 DualWAN: skip single wan wan_led_control - WANRED off
Apr 18 21:28:08 nat: apply redirect rules
Apr 18 21:28:08 rc_service: httpd 276:notify_rc restart_wan_if 0
Apr 18 21:28:09 kernel: Attempt to kill tasklet from interrupt
Apr 18 21:28:11 wan: [wan0_hwaddr] == [AC:9E:17:49:63:90]
Apr 18 21:28:11 pppd[2751]: pppd 2.4.7 started by admin, uid 0
Apr 18 21:28:11 pppd[2751]: Connected to 00:00:5e:00:01:51 via interface eth0
Apr 18 21:28:11 pppd[2751]: Connect: ppp0 <--> eth0
Apr 18 21:28:11 wan: [deconfig] udhcpc done[286]
Apr 18 21:28:14 pppd[2751]: PAP authentication succeeded
Apr 18 21:28:14 pppd[2751]: peer from calling number 00:00:5E:00:01:51 authorized
Apr 18 21:28:14 pppd[2751]: local IP address 173.185.76.237
Apr 18 21:28:14 pppd[2751]: remote IP address 98.20.104.1
Apr 18 21:28:14 pppd[2751]: primary DNS address 166.102.165.13
Apr 18 21:28:14 pppd[2751]: secondary DNS address 207.91.5.20
Apr 18 21:28:14 rc_service: ip-up 2756:notify_rc start_firewall
Apr 18 21:28:15 miniupnpd[2063]: shutting down MiniUPnPd
Apr 18 21:28:15 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 21:28:15 wan: finish adding multi routes
Apr 18 21:28:15 rc_service: ip-up 2756:notify_rc stop_upnp
Apr 18 21:28:15 rc_service: waitting "start_firewall" via ip-up ...
Apr 18 21:28:15 miniupnpd[2790]: version 1.9 started
Apr 18 21:28:15 miniupnpd[2790]: HTTP listening on port 50346
Apr 18 21:28:15 miniupnpd[2790]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:28:16 rc_service: ip-up 2756:notify_rc start_upnp
Apr 18 21:28:16 rc_service: waitting "stop_upnp" via ip-up ...
Apr 18 21:28:16 miniupnpd[2790]: shutting down MiniUPnPd
Apr 18 21:28:17 miniupnpd[2792]: version 1.9 started
Apr 18 21:28:17 miniupnpd[2792]: HTTP listening on port 37069
Apr 18 21:28:17 miniupnpd[2792]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:28:18 rc_service: httpd 276:notify_rc start_autodet
Apr 18 21:28:30 WAN Connection: WAN was restored.
Apr 18 21:28:31 rc_service: httpd 276:notify_rc restart_wan_if 0
Apr 18 21:28:32 rc_service: httpd 276:notify_rc start_webs_update
Apr 18 21:28:32 rc_service: waitting "restart_wan_if 0" via httpd ...
Apr 18 21:28:32 rc_service: zcip 2816:notify_rc start_firewall
Apr 18 21:28:33 kernel: Attempt to kill tasklet from interrupt
Apr 18 21:28:35 wan: [wan0_hwaddr] == [AC:9E:17:49:63:90]
Apr 18 21:28:35 wan: [deconfig] udhcpc done[286]
Apr 18 21:28:35 pppd[2858]: pppd 2.4.7 started by admin, uid 0
Apr 18 21:28:36 zcip client: configured 0.0.0.0
Apr 18 21:28:37 miniupnpd[2792]: shutting down MiniUPnPd
Apr 18 21:28:37 nat: apply nat rules (/tmp/nat_rules__eth0)
Apr 18 21:28:38 miniupnpd[2911]: version 1.9 started
Apr 18 21:28:38 miniupnpd[2911]: add_filter_rule() : chain FUPNP not found
Apr 18 21:28:38 miniupnpd[2911]: Failed to redirect 9308 -> 192.168.1.214:9308 protocol UDP
Apr 18 21:28:38 miniupnpd[2911]: HTTP listening on port 39881
Apr 18 21:28:38 miniupnpd[2911]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:28:39 rc_service: ip-up 2756:notify_rc start_firewall
Apr 18 21:28:40 miniupnpd[2911]: shutting down MiniUPnPd
Apr 18 21:28:40 nat: apply nat rules (/tmp/nat_rules__eth0)
Apr 18 21:28:41 miniupnpd[2982]: version 1.9 started
Apr 18 21:28:41 miniupnpd[2982]: add_filter_rule() : chain FUPNP not found
Apr 18 21:28:41 miniupnpd[2982]: Failed to redirect 9308 -> 192.168.1.214:9308 protocol UDP
Apr 18 21:28:41 miniupnpd[2982]: HTTP listening on port 56926
Apr 18 21:28:41 miniupnpd[2982]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:28:50 WAN Connection: Fail to connect with some issues.
Apr 18 21:28:50 DualWAN: skip single wan wan_led_control - WANRED off
Apr 18 21:28:50 nat: apply redirect rules
Apr 18 21:28:56 rc_service: zcip 3029:notify_rc start_firewall
Apr 18 21:28:56 zcip client: configured 169.254.157.248
Apr 18 21:28:57 miniupnpd[2982]: shutting down MiniUPnPd
Apr 18 21:28:57 nat: apply nat rules (/tmp/nat_rules__eth0)
Apr 18 21:28:57 miniupnpd[3049]: version 1.9 started
Apr 18 21:28:57 miniupnpd[3049]: add_filter_rule() : chain FUPNP not found
Apr 18 21:28:57 miniupnpd[3049]: Failed to redirect 9308 -> 192.168.1.214:9308 protocol UDP
Apr 18 21:28:57 miniupnpd[3049]: HTTP listening on port 47484
Apr 18 21:28:57 miniupnpd[3049]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:29:00 nat: apply redirect rules
Apr 18 21:29:01 rc_service: httpd 276:notify_rc restart_wan_if 0
Apr 18 21:29:01 pppd[2858]: Unable to complete PPPoE Discovery
Apr 18 21:29:01 kernel: Attempt to kill tasklet from interrupt
Apr 18 21:29:03 wan: [wan0_hwaddr] == [AC:9E:17:49:63:90]
Apr 18 21:29:03 pppd[3083]: pppd 2.4.7 started by admin, uid 0
Apr 18 21:29:03 pppd[3083]: Connected to 00:00:5e:00:01:51 via interface eth0
Apr 18 21:29:04 pppd[3083]: Connect: ppp0 <--> eth0
Apr 18 21:29:06 pppd[3083]: PAP authentication succeeded
Apr 18 21:29:06 pppd[3083]: peer from calling number 00:00:5E:00:01:51 authorized
Apr 18 21:29:07 pppd[3083]: local IP address 67.140.122.250
Apr 18 21:29:07 pppd[3083]: remote IP address 98.20.104.1
Apr 18 21:29:07 pppd[3083]: primary DNS address 166.102.165.13
Apr 18 21:29:07 pppd[3083]: secondary DNS address 207.91.5.20
Apr 18 21:29:07 rc_service: ip-up 3097:notify_rc start_firewall
Apr 18 21:29:07 miniupnpd[3049]: shutting down MiniUPnPd
Apr 18 21:29:08 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 21:29:08 wan: finish adding multi routes
Apr 18 21:29:08 rc_service: ip-up 3097:notify_rc stop_upnp
Apr 18 21:29:08 rc_service: waitting "start_firewall" via ip-up ...
Apr 18 21:29:08 miniupnpd[3147]: version 1.9 started
Apr 18 21:29:08 miniupnpd[3147]: HTTP listening on port 60080
Apr 18 21:29:08 miniupnpd[3147]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:29:09 rc_service: ip-up 3097:notify_rc start_upnp
Apr 18 21:29:09 rc_service: waitting "stop_upnp" via ip-up ...
Apr 18 21:29:09 miniupnpd[3147]: shutting down MiniUPnPd
Apr 18 21:29:10 miniupnpd[3149]: version 1.9 started
Apr 18 21:29:10 miniupnpd[3149]: HTTP listening on port 37318
Apr 18 21:29:10 miniupnpd[3149]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:29:15 rc_service: zcip 3163:notify_rc start_firewall
Apr 18 21:29:15 zcip client: configured 169.254.157.248
Apr 18 21:29:16 miniupnpd[3149]: shutting down MiniUPnPd
Apr 18 21:29:16 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 21:29:17 miniupnpd[3181]: version 1.9 started
Apr 18 21:29:17 miniupnpd[3181]: HTTP listening on port 57910
Apr 18 21:29:17 miniupnpd[3181]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:29:20 WAN Connection: WAN was restored.
Apr 18 21:29:30 rc_service: ip-up 3097:notify_rc start_firewall
Apr 18 21:29:30 miniupnpd[3181]: shutting down MiniUPnPd
Apr 18 21:29:31 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 21:29:31 miniupnpd[3247]: version 1.9 started
Apr 18 21:29:31 miniupnpd[3247]: HTTP listening on port 57575
Apr 18 21:29:31 miniupnpd[3247]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 21:31:50 rc_service: httpd 276:notify_rc start_sig_check
Apr 18 21:31:52 rc_service: httpd 276:notify_rc start_webs_update
Apr 18 21:31:52 rc_service: waitting "start_sig_check" via httpd ...
Apr 18 21:32:07 rc_service: skip the event: start_webs_update.
And another:
Apr 18 22:05:26 rc_service: httpd 276:notify_rc restart_wan_if 0
Apr 18 22:05:26 WAN Connection: Fail to connect with some issues.
Apr 18 22:05:26 DualWAN: skip single wan wan_led_control - WANRED off
Apr 18 22:05:27 nat: apply redirect rules
Apr 18 22:05:28 kernel: Attempt to kill tasklet from interrupt
Apr 18 22:05:30 wan: [wan0_hwaddr] == [AC:9E:17:49:63:90]
Apr 18 22:05:30 pppd[4503]: pppd 2.4.7 started by admin, uid 0
Apr 18 22:05:30 pppd[4503]: Connected to 00:00:5e:00:01:51 via interface eth0
Apr 18 22:05:30 pppd[4503]: Connect: ppp0 <--> eth0
Apr 18 22:05:34 pppd[4503]: PAP authentication succeeded
Apr 18 22:05:34 pppd[4503]: peer from calling number 00:00:5E:00:01:51 authorized
Apr 18 22:05:34 pppd[4503]: local IP address 173.185.65.34
Apr 18 22:05:34 pppd[4503]: remote IP address 98.20.104.1
Apr 18 22:05:34 pppd[4503]: primary DNS address 166.102.165.13
Apr 18 22:05:34 pppd[4503]: secondary DNS address 207.91.5.20
Apr 18 22:05:34 rc_service: ip-up 4508:notify_rc start_firewall
Apr 18 22:05:34 miniupnpd[4207]: shutting down MiniUPnPd
Apr 18 22:05:35 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 22:05:35 wan: finish adding multi routes
Apr 18 22:05:35 rc_service: ip-up 4508:notify_rc stop_upnp
Apr 18 22:05:35 rc_service: waitting "start_firewall" via ip-up ...
Apr 18 22:05:35 miniupnpd[4542]: version 1.9 started
Apr 18 22:05:35 miniupnpd[4542]: HTTP listening on port 36433
Apr 18 22:05:35 miniupnpd[4542]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 22:05:36 rc_service: ip-up 4508:notify_rc start_upnp
Apr 18 22:05:36 rc_service: waitting "stop_upnp" via ip-up ...
Apr 18 22:05:36 miniupnpd[4542]: shutting down MiniUPnPd
Apr 18 22:05:37 miniupnpd[4544]: version 1.9 started
Apr 18 22:05:37 miniupnpd[4544]: HTTP listening on port 57492
Apr 18 22:05:37 miniupnpd[4544]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 22:05:41 rc_service: zcip 4558:notify_rc start_firewall
Apr 18 22:05:41 zcip client: configured 169.254.157.248
Apr 18 22:05:42 miniupnpd[4544]: shutting down MiniUPnPd
Apr 18 22:05:42 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 18 22:05:43 miniupnpd[4576]: version 1.9 started
Apr 18 22:05:43 miniupnpd[4576]: HTTP listening on port 60161
Apr 18 22:05:43 miniupnpd[4576]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 18 22:05:46 WAN Connection: WAN was restored.
The first guess would be (as yours) that the ISP has problems - of course they swear not, but still this would be my bet! ;)
In the meantime you can restart (with power down for some minutes) the modem and router - and then wait an see!
Either one of your devices is dying (unlikely) or your ISP has temporary issues which they do not recognize yet - had this in the past with my ISP. :rolleyes:
The last resort could be a failing cable (between ISP, modem or router).
It seemed to fix itself, but here I am again, as it's started reoccurring.
It's happened twice today. Here's a log of the latest time:
Apr 27 07:18:18 pppd[15752]: Serial link appears to be disconnected.
Apr 27 07:18:19 WAN Connection: Fail to connect with some issues.
Apr 27 07:18:20 DualWAN: skip single wan wan_led_control - WANRED off
Apr 27 07:18:20 nat: apply redirect rules
Apr 27 07:18:24 pppd[15752]: Connection terminated.
Apr 27 07:18:24 pppd[15752]: Modem hangup
Apr 27 07:18:34 pppd[15752]: Connected to 00:00:5e:00:01:51 via interface eth0
Apr 27 07:18:34 pppd[15752]: Connect: ppp0 <--> eth0
Apr 27 07:18:38 pppd[15752]: PAP authentication succeeded
Apr 27 07:18:38 pppd[15752]: peer from calling number 00:00:5E:00:01:51 authorized
Apr 27 07:18:38 pppd[15752]: local IP address 98.20.8.81
Apr 27 07:18:38 pppd[15752]: remote IP address 98.20.104.1
Apr 27 07:18:38 pppd[15752]: primary DNS address 166.102.165.13
Apr 27 07:18:38 pppd[15752]: secondary DNS address 207.91.5.20
Apr 27 07:18:38 rc_service: ip-up 9468:notify_rc start_firewall
Apr 27 07:18:39 wan: finish adding multi routes
Apr 27 07:18:39 rc_service: ip-up 9468:notify_rc stop_upnp
Apr 27 07:18:39 rc_service: waitting "start_firewall" via ip-up ...
Apr 27 07:18:39 miniupnpd[7808]: shutting down MiniUPnPd
Apr 27 07:18:40 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 27 07:18:40 miniupnpd[9502]: version 1.9 started
Apr 27 07:18:40 rc_service: ip-up 9468:notify_rc start_upnp
Apr 27 07:18:40 rc_service: waitting "stop_upnp" via ip-up ...
Apr 27 07:18:41 miniupnpd[9502]: HTTP listening on port 35997
Apr 27 07:18:41 miniupnpd[9502]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 27 07:18:41 miniupnpd[9502]: shutting down MiniUPnPd
Apr 27 07:18:42 miniupnpd[9504]: version 1.9 started
Apr 27 07:18:42 WAN Connection: WAN was restored.
Apr 27 07:18:42 miniupnpd[9504]: HTTP listening on port 55715
Apr 27 07:18:42 miniupnpd[9504]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 27 07:19:01 rc_service: ip-up 9468:notify_rc start_firewall
Apr 27 07:19:01 miniupnpd[9504]: shutting down MiniUPnPd
Apr 27 07:19:01 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Apr 27 07:19:02 miniupnpd[9588]: version 1.9 started
Apr 27 07:19:02 miniupnpd[9588]: HTTP listening on port 59521
Apr 27 07:19:02 miniupnpd[9588]: Listening for NAT-PMP/PCP traffic on port 5351
Curiously enough, at the start time, it was 7:18:18 which is exactly 2 hours after the last time it happened.
