Mr_Doughboy
Just purchased the AC87U but seem to be having issues with the WWAN renew and just wondered if anyone else had experienced the same issue ?
If my WWAN connection goes down for a few minutes due to bad weather (mostly due to my line) and reconnects the AC87U does not appear to renew its DHCP?
When the WWAN regains connection it does not appear to renew the IP, I have to manually login to the router and reboot.
Once restarting everything works perfectly again but the router should be doing this automatically...
Is this a firmware bug ? I've tried merlins firmware but unfortunately this causes streaming issues causing the router to "lock up" after 3+ days of usage.
Thanks for any advice!
