I have problems with my new router, I tried all firmwares available for RT-AC87U, but it still persists.
1- I received a lot of messages in the system log: 'kernel: Dead loop on virtual device vlan2, fix it Urgently! 'And I followed the advice I've seen in the various threads about this problem. rMerlin said that asus had solved this problem and it was related to adaptive QoS. but on my router this feature is already off. The only way I've found to prevent this problem from spamming my system log is to turn off AiProtection ( -malicious sites blocking, -vulnerability protection, -infected device prevention and blocking ) and no more error. I want to know if its dangerous to keep Aiprotection on because at the end of the error its written : fix it urgently!.
2- The DLNA server stops working by itself. After a while it works again or I need to reboot the router. its annoying... do you have a similar problem?
3- I got unknown phone devices showing in windows 8 network list. It appears and disappears. it shows the device name and the mac adress only, no ip adress. Nothing Appears in my Client list on the router page. I needed to turn off WPS and disable the windows service : WCNCSVC (Windows Connect Now) to prevent seeing it. Is this normal? (note: i have a old d-link router dir-610 and i dont see unknown device in my network list)
4- its nothing but my antenna unscrews itself when i rotated it. I need to hold it before rotate it XD its nothing but its just annoying.
I was thinking to return my router and get a older model ,maybe it will have more mature firmware...
What do you think about it and from your experience do you think older model have stable dlna server and no problem in system log when activating router's features?
Sorry i usually speak french so maybe my english is not perfect.
