So I had an Asus RT-N66U that was running merlins firmware version 378.54_2. I was starting to get some range issues and also speed issues. We just got upgraded to RCN's 155/15 connection so the performance was quite there for my internet connection, I would get about 100 over wifi and only about 135 over wired, when directly out of the modem I was getting closer to 180-200.
So I decided to get an Asus RT-AC87U at best buy yesterday. I know they have the 5Ghz issue with them. I have merlins firmware version 378.55 on it and so far it seems to be working well. I also got the geek squad protection since I knew that there were some issues with the 5Ghz and they said if it keeps dropping signal they will replace it and if that model isn't available anymore they replace it with the newer model.
So my main question is did I make a mistake buying the RT-AC87U in hoping I might get lucky and have it work well for me? I can still return it to best buy. Or I can hang on to it and if I do end up having the issues with the 5Ghz that many say are inevitable, I can take advantage of the geek squad replacement when the RT-AC88U hits the shelves?
