RT-AC87U
Marcogv
I can't upgrade my router RT-AC87U firmware to 384.9.
It seems to work but the router remains displaying 384.7-2 as the firmware version after it reboots.
I tried over and over again without success.
What else can I do?
P.D. I use the browser interface to load the file RT-AC87U_384.9_0.trx.
It worked just fine with previous versions.
Reboot the router with no USB disk plugged in, then try flashing again.
Double check that you got the right model, and try a different browser.
