RT-AC88U 5G range Less Than 2G
Biggupp
firmware = 3.0.0.4.380_3941-g27d8adf
In one area of my home, 2G on an IPhone 6S gets a better signal than does 5G. I just reset the router and reconfigured it, but no difference. Moving the router isn't really an option. Why would one be stronger than the other and how can I improve the signal?
You could try turning the router orientation just slightly maybe 5 degrees at a time. That worked for me!
The 2.4 ghz will always have a longer range than 5ghz. It's physics.
That is the nature of RF signals.
All of the other replies explain the range difference between the two radio bands, but Csection's reply to the second half of your question correctly suggests a method to try to improve the signal. 5.8GHz radio waves are only 52mm long, so small changes in position can make a big difference due to reflection and refraction.
Thank you for the kind words! I don't make many replies cause my knowledge level is not up to most one here. I only know what works for me.
I did do some serious testing on long range wifi though cause a client of mine needed to connect from a steel building to his house(Apprx 50meters away). I ended up cutting a small hole through the quansit wall and adding a flat panel(Less directional than a yagi) antenna to reach the house. It worked well for him. I also connect from my house to my daughter's house on 5ghz(About 50ft through 3 walls).
