RT-AC88U sees all USB3 disks as USB 2
Wulfie
I just purchased this router, before i return it, i was wondering if anyone had same issue. I am running Merlin firmware 384.9, and any and all USB disk/pen etc show up as USB 2. I read in other forums something in the 2.4 wireless settings to disable usb inteference. I cannot find that in the professional section. If anyone can advise me, I was thinking of loading up the stock firmware to see if it resolves. Rgds.
Wulfie
Please do not crosspost. See my answer in the other thread you started.
Here's the log, i see no superspeed, maybe thats it???
Feb 22 23:04:32 kernel: xhci_hcd 0000:00:0c.0: xHCI Host Controller
Feb 22 23:04:32 kernel: xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 1
Feb 22 23:04:32 kernel: xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
Feb 22 23:04:32 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Feb 22 23:04:32 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Feb 22 23:04:32 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Feb 22 23:04:33 kernel: hub 1-0:1.0: USB hub found
Feb 22 23:04:33 kernel: hub 1-0:1.0: 1 port detected
Feb 22 23:04:33 kernel: [xhci-hub] usb2mode:[0]
Feb 22 23:04:33 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 22 23:04:33 kernel: ehci_hcd 0000:00:0b.1: EHCI Host Controller
Feb 22 23:04:33 kernel: ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
Feb 22 23:04:33 kernel: ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
Feb 22 23:04:33 kernel: ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
Feb 22 23:04:33 kernel: hub 2-0:1.0: USB hub found
Feb 22 23:04:33 kernel: hub 2-0:1.0: 2 ports detected
Feb 22 23:04:33 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Feb 22 23:04:33 kernel: ohci_hcd 0000:00:0b.0: OHCI Host Controller
Feb 22 23:04:33 kernel: ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 3
Feb 22 23:04:33 kernel: ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
Feb 22 23:04:33 kernel: hub 3-0:1.0: USB hub found
Feb 22 23:04:33 kernel: hub 3-0:1.0: 2 ports detected
Feb 22 23:04:33 kernel: SCSI subsystem initialized
Feb 22 23:04:33 kernel: Initializing USB Mass Storage driver...
Feb 22 23:04:33 kernel: usbcore: registered new interface driver usb-storage
Feb 22 23:04:33 kernel: USB Mass Storage support registered.
Feb 22 23:04:33 kernel: Tuxera FAT 12/16/32 driver version 3015.1.29.5 [Flags: R/W MODULE].
Feb 22 23:04:33 kernel: Built against headers 2.6.36.4brcmarm #3 SMP PREEMPT Mon Sep 3 18:00:49 CST 2018 arm
Feb 22 23:04:33 kernel: Running on kernel 2.6.36.4brcmarm #1 SMP PREEMPT Sat Feb 2 13:28:19 EST 2019 armv7l
Feb 22 23:04:34 kernel: Tuxera NTFS driver 3018.6.22d [Flags: R/W MODULE].
Feb 22 23:04:34 kernel: Built against headers 2.6.36.4brcmarm #3 SMP PREEMPT Mon Sep 3 18:00:49 CST 2018 arm
Feb 22 23:04:34 kernel: Running on kernel 2.6.36.4brcmarm #1 SMP PREEMPT Sat Feb 2 13:28:19 EST 2019 armv7l
Feb 22 23:04:34 kernel: Tuxera HFS+ driver 3017.6.20
Feb 22 23:04:34 kernel: usbcore: registered new interface driver usblp
Feb 22 23:04:34 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 2
Feb 22 23:04:34 kernel: scsi0 : usb-storage 2-2:1.0
