TimRedBeard
My current setup is a Netgear CM1200 Modem with Cox Gigablast and I'm running a RT-AC88U with Asuswrt-Merlin 384.19. I was having great download speed between 800-920 down without issues. My upload speeds have been consistent at 35 up. However now I can't get my speeds above 520 down at all. I've done everything I can think of. I've searched the forums and tried every kind of settings that I've found to try and get the best speeds. Does anyone have any suggestions on how to help me get better download speeds?
QoS is off
AiProtection is off
Jumbo Frame - Disabled
NAT Acceleration - Auto (CTF is enabled)
Spanning-Tree Protocol - Enabled
Link agg - Disabled
Enable WAN - Yes
Enable NAT - Yes
UPnP - No
Connect DNS Server Automatically - Yes
Any help would be great, I don't know what else I can do except reset the router and start fresh. Thank you in advance.
QoS is off
AiProtection is off
Link agg - Disabled
Enable WAN - Yes
Enable NAT - Yes
UPnP - No
