ThereIsNoName
Hi!
When there is a lot of traffic passing through the NAT, an ASUS RT-AC66U, the admin GUI and secondary built in services such as DNS stops working. The admin GUI gets timeouts and it seem the same occurs for the DNS cache/proxy server.
And with a lot of traffic I mean in the range of 80 - 100 Mbit.
I am currently using Firmware version: 3.0.0.4.378_9533, which the router downloaded and installed automatically from ASUS site.
I am only interested in the following functionality:
- NAT
- Reverse NAT (port mapping)
- Firewall
- Wireless 5 Ghz Access Point
- DHCP (for clients)
- DNS-proxy server for connected clients
- A working Admin GUI (even with high traffic)
My questions
1. Will your Merlin FirmWare solve these problems?
2. How can I be sure this Merlin FirmWare is secure and that no one introduced backdoors or anything like that?
///H
PS I understand that things will be slower when there is a lot of traffic through the NAT, but it should still work. Especially the admin GUI needs to always work so any issues can be fixed. The admin GUI should run in a process with high enough priority to make sure you always can run it, even if it means that you limit throughput or even start to drop packages. Since it is a web site, even with a very high priority, it will not affect the NAT unless someone is actually using the Admin GUI. And if a request to the admin GUI ever times out, then a very simple page where you can limit, or even pause, traffic for the next few minutes, so you can get in and fix whatever it is you need to do.
- NAT
- Firewall
My questions
///H
