RT-AX11000 - HTTP Connection from 192.168.1.85 closed unexpectedly
wizin
Hello Gents
Please help with thw following error which pops up over and over - affects the IPTV app on my mothers TV.
The TV blacks out and I see this error, happens over and over
upnp is disabled
These are series of error in the log
She just cant enjoy TV, the same app works on other places and IPTV boxes
Attached log
  • log.txt
upnp is disabled
Obviously it isn't because that message is coming from miniupnpd. Check under Adaptative QoS > QoS as that also has an option ("Enable GeForce NOW QoS UPnP control") that enables UPnP. Also check "Aura RGB" which also does.
If I were you I'd also be concerned about the constant dcd process crashes on your router. This is usually caused be an incompatibility between TrendMicro and one or more of your add-on scripts (e.g. Diversion's Pixelserv).
Thats another headache, so what I should I do? disable trendmicro
I checked all places for UPNP, all are off, now tried to enable/disable so lets see
Edit: Enable UPNP Media Server was ON - damn
