RT-AX3000V2, RT-AX58UV2, TUF-AX3000V2
PeterLiljedahl
Hello everyone, I am trying to discern the various differences between these 3 routers.
Looking at these pages:
There seem to be very little differences between them except the LAN chips
which seems to differ in model and make however they all seem to be 2.5GbE for WAN and 4x1GbE LAN
and that the TUF version seems to use additional amplifiers for the 2 and 5 GHz for some reason (increased range) maybe.
Can we conclude that all three supports 2.5GbE for the WAN port to connect to the router if used as a mesh node?.
Asus homepage is a little unclear when it comes to compare devices because there are v1 devices also mixed in
which uses older SOCs and whatnot.
No.
RT-AX58U V2, RT-AX3000 V2 - exactly the same router with different marketing, no 2.5GbE WAN port
TUF-AX3000 V2 - one of the Gaming marketing variants of the above hardware with 2.5GbE WAN port
