RT-AX56U
When testing wifi with iperf I have only ~350-400Mbps, when using reverse option I get ~900Mbps
I tried 2 latest official firmware 3.0.0.4.386_51679, 3.0.0.4.386.51665 and two merlin 3004.388.8_2, 3004.388.6_2. After each update I reset to factory then set up 5GHz network trough quick setup (just password and ssid) and tested that way, so settings were mostly automatic.
On both 3004.388.8_2, 3004.388.6_2 I tried all different settings in wifi section. For now I have set AX only 80 Mhz.
I tried disabling universal and AX beamforming, disabling OFDMA, to no difference (I'm actually surprised that disabling OFDMA still yields 800Mbps when reversed testing)
I have also tested in AC mode and speeds were as much asymmetric as in AX mode.
When I first bought the router I think I was getting 600-700 when iperf testing without reverse but it was long time ago. So I'm not sure if my router has somehow broken or it was like that from factory. I wish someone who also owns this router could test that.
(Testing with -P 2 or higher does not improve much, and -P 1 results were more compact to fit here)
Tests are made from wifi client to wired server:
I tried another wifi client (quest2):
Other router test (Cudy WR3000):
client -> server
| server -> client
client -> server (wired)
client -> server
| server -> client
client -> server
| server -> client
