So what is the advantage of of the Extra Core that the AX56U have?Wifi will be slightly better with the RT-AX58U. Both will have identical OpenVPN performance.
Judging from the frequency of Asus firmware releases, looks like they update the RT-AX58U more frequently at this time.
But its wierd that the AX56U has probably the better CPU
might possibly be dedicated to specific usage.
This gentleman @Jayce Ooi did a video review of AX56U.
https://www.snbforums.com/threads/review-asus-rt-ax56u.63967/
@3.52, 4th CPU core is loaded fully during USB file transfers (I believe).
So Overall i the RT-AX58U is more recommented? Are there any known issues with the Router?Yes, and it's actually a design flaw in that firmware version, because the archer service is also bound to that same CPU core, slowing down SMB performance to about 70 MB/s max. I fixed this issue in my firmware, and relayed the fix to Asus.
If a flaw is causing SMB to slow to 70MB/s what sort of speeds are people seeing on these 2 routers when working properly?
So i bought the ASUS RT-AX58U. The OPENVPN Speeds is about 10-12Mbps slower then the AX56U. In the first few tests i got about 58-60Mbps. (With AES256)Mine was hitting read speeds of a bit over 100 MB/s after I fixed CPU affinity.
One is quad-core and one is tri-core, I'm not sure about other differences they may (or may not) have implemented in each.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
