I can't get aimesh to work on RT-AX58U V2 with two ac68u clients.
It 'sees' the clients but is unable to pair up with it. It gets slowly to 40% progress then speeds up then says it's unable to pair up,
with the following error:
Unable to add your AiMesh node RT-AC68U (mac:address:goes:here) to your AiMesh system due to the following situations. Please check and try again.
The firmware is 3.0.0.4.388_24762-ge3b6352 and the clients have the latest firmware.
Is this firmware known to cause aimesh to stop working? The clients have all been reset as per recommendations.
It used to work until an automatic update upgraded it. I tried to fix it by removing the client entries,
resetting the clients, rebooting the master and attempting to re-add the clients. Also tried via ethernet.
- Someone else is trying to set up an AiMesh system. Please wait 1 minute and try again.
- your AiMesh router and node should be within 3 meters of each other during the setup process.
- Make sure your AiMesh node is powered on.
- Your AiMesh node has been upgraded to AiMesh-supported firmware.
- Your AiMesh node has been reset to default
