Hi all, new to this form.
I have a Raspberry pi 4 running LibreELEC and Kodi with OpenVPN and Nord VPN. My issue is I have 500 Mbps fiber internet and with the VPN turned on I only get 150 ish Mbps. Doing a search to find a resolve I learned that OpenVPN is very slow.
According to Nord I can install Nord on my router however the router also uses OpenVPN (according to the info from Nord). If that is true and if i functions as poorly on the router I have no desire to use it.
My question is: What results to you all have when installing a VPN on this router and how do set it up. Must OpenVPN actually be used? I have two wired connections that I want to use the VPN for so is there a way to only have those two connections
protected by the VPN.
Thank You in advance for your assistance.
