anthonyng5p
ok. i may give it a try this weekend and report back.
My 5GHz SSID changed after upgrading, corrected/changed back manually, no big deal but interesting...Decided to flash and then hard reset, since it’s been a while. Got through the setup wizard and it just hung up. After a few minutes, I could access the router with new login credentials, but with the default ssid and no wifi security.
reset and tried 3 different times. Had to ssid manually. Not a huge deal, but that’s never happened before.
Time would be the hours you are allowing access.can someone tell me what is the difference between these options?
I chose the "block" and specified the time - the Internet did not work all day. so I think you're wrong.Time would be the hours you are allowing access.
Block would be the hours you are blocking access.
Time - Internet is off during the timeframe(s) you select.can someone tell me what is the difference between these options?
amazon replaced the unit and now the wifi bands are solid.
No matter which channel or settings i used for the 5ghz band it was disapeering randomly and reconnecting.
on a plus note
Wifi around the house is alot faster on the ax86u, an xbox series x gets nearly full speed testing the connection on the xbox through 5ghz band.
Welcome To SNBForums
