RT-AX86U 2.4ghz & 5ghz dropouts
stevejmcmurray
Hi I have an ASUS RT-AX86U router connected to my NBN modem that distributes the signal throughout my house. The router is located on the bottom floor in the back corner of the house and is kept inside a kitchen cupboard under the bench. I know this is not a great spot but it is the only spot that suits for the time being. The issue I am having is that both 5ghz and 2.4ghz are having dropouts - this happens a bit and we are having to reset the router to clear the issue.
What solutions would be most cost effective to make the wireless network more robust ? Should I be getting another ASUS and running an AIMESH connection to the other end of the house to ease congestion on the single router ? Or would a ethernet over power backbone to another router be better ?
Any help or suggestions are appreciated
Cheers
Steve
What congestion on a single router? Your router is perhaps constantly hunting for better channel and more bandwidth on Auto settings and this is causing the device disconnections. Some devices may not reconnect if the router jumps in DFS range control channel. Lock 2.4GHz at channel 6 and 20MHz bandwidth and 5GHz on channel 36 and 80MHz bandwidth and try again. The Wi-Fi settings are there for a reason. And take the router out of the cupboard. It has passive cooling and needs some air circulation. This is the worst place to keep a device like this and it may be overheating.
Thanks for the suggestions - I am no expert in this so any advice is appreciated. Getting the router out of the cupboard is the problem as I said before this is where the NBN modem is. Could I use a Ethernet over power adapter to connect the modem and the router and get the router in a more suitable spot this way ?
You can, but this may degrade your Internet line quality significantly. Power line adapters are not very reliable and most are slow.
