Hey,
I've tested three cables so far on the 2.5G LAN port of my RT-AX86U (386.7_2), using iperf3 with 10 parallel streams.
I'm seeing these errors on the router with all three cables (and about 1.24 GBit throughput only), when sending data from the AX86U:
`iperf3 -c IP -P 10` on the router, `iperf3 -s` on the other machine, which is connected through a 2.5G switch.
Has anyone else observed this? It's pretty obvious that in TX the router has issues. All three cables are at least CAT 5e certified and 10m in length.
This only happens with 10 parallel streams. With a single stream the errors don't show up, but the speed is still way below 2.5G.
RX is doing 2.3 GBit without any errors. Including overhead, that's 2.5G.
Edit: All filtering disabled, trendmicro declined.
Sep 23 15:15:08 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=15361
Sep 23 15:15:10 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=16385
Sep 23 15:15:13 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=17409
Sep 23 15:15:16 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=18433
Sep 23 15:15:22 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=19457
Sep 23 15:15:25 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=20481
Sep 23 15:15:29 kernel: ERR: rdpa_cpu_tx_port_enet_lan#213: rdpa_cpu_tx_port_enet_lan failed. rdd_rc=120 tx_rdd_error_count=21505
