vStache
I have been using Merlin Firmware for multiple years on RT-AX86U. I make use of a number of extensions such as JFFS, DNS Filter, VPN Director, etc. I moved to 388.1 when it was released in Dec 2022 and had random connectivity issues. I moved back to 386.7.2 which has no issues.
Recently, I acquired another RT-AX86U and set it up from scratch on Merlin 388.1 (not using JFFS or DNS Director) and have the same issues. It looks like DNS resolution fails.
I moved the router to the current stock firmware (without even resetting) and everything works (of course stock f/w doesn't support JFFS and DNS Director which I have not used on the new router yet).
I was hoping that 388.2 would fix these issues. But when I used 388.2 B1 on the router, same connectivity issues returned.
My DNS setup uses DoT and DNSSec. I tried using different DNS providers ranging from Google, Clean Browsing and Quad9. The issues are the same.
This DNS setup works on Merlin 386.7.2 and current stock firmware.
I even tried switching DoT and DNSSec off but the issues remain.
Any help or guidance is appreciated as I would like to move my main router to the latest versions in case there are security upgrades.
