Any performance config recommendations greatly appreciated, just installed w/factory specs, download went from 300 Mbps maximum (AC68U) to 700Mbps.
While OzarkEdge has a detailed write up, I have my own opinions for the AX86U:Any performance config recommendations greatly appreciated, just installed w/factory specs, download went from 300 Mbps maximum (AC68U) to 700Mbps.
I use the Asus firmware with auto upgrade enabled.
Now that everything is humming along nicely,
Roku did get an upgrade recently. One addition is a sleep mode. It also seems to follow the routers WIFI channel switching better. I continue to switch the WIFI settings to see what happens and what works best. Also switch DoT and DNS Server 1/2 from time to time. Quad9 was wonky today so I switched to Cloudflare Secure which fixed things for now.This is your only configuration preference I would take exception to... I prefer to upgrade my network on my schedule when I have time to manage the interruption and any surprises for me and my users.
I suppose if I ever need DoS protection, I'll enable it. The AX86U probably wouldn't notice!
I initially disabled the login Captcha, but then I realized it permits me to use a simple admin password and not think twice about it.
Now that everything is humming along nicely, I may tryout 160 MHz on the lower end of the 5.0 band. I like that the Wireless Log now lists client bandwidth... we can now see that lessor clients are using their smaller bandwidth no matter what bandwidth is configured on the router.
I recently rebooted my Roku and it moved its WiFi Direct AP (used by its remote controller/clicker) up to channel 165... that's a good, otherwise useless channel for it... I hope it stays there. I wonder if a Roku firmware upgrade caused that change.
OE
Oh, the Auto Upgrade works well for folks who are computer illiterate. I set up an AC86U for some friends that are like that and the router got the last big upgrade and just kept humming along!
What I do
Why did you mix the routers? New AX capable devices?
No, I bought the AX86U to replace an AC86U I thought was failing. I only have one AX client and it is wired... I haven't even tried AX yet. It's all good... I'm learning.
Yep, same thing with my setup. Have to manually enable 160MHz for both of my AX clients to connect at 160. The auto setting should work, maybe they'll fix in future firmware update.Today, I introduced my one AX PC client to my AX86U... they got along great after I figured out some things. In particular, I had to set 5.0 to 160 MHz to get the AX client to connect at 160 MHz; 20/40/80/160 MHz would only connect at 80 MHz. As it turns out, the firmware falls back nicely from 160 MHz to the lower bandwidths for lessor clients. Similarly, setting WPA2/WPA3-Personal (AES) everywhere seems to suit all of my clients (although I did not roam today).
I am purposely restricting the 5.0 control channel to the non-DFS channels 36-48.
Here is a pic of the 5.0 Log showing various bandwidth connections. The 4-stream AC 80 MHz connection is my AC86U node... someday that will become a 4-stream AX 160 MHz connection:
I have updated my install notes accordingly.
OE
When set to Auto, it picks ch 48 ( i also tried 40 44 36) and my 5GHZ doesnt appear. They only other channels that are available are 52-144 but Asus wireless utility is showing them all radar sensitive. Any idea why my AX86U wont show the 5GHZ ch at 160 between 36-48 band?
How long did it take for the 5GHZ to show back up...usually its come up right away...I may have to give a couple of minutes to settle?Auto picked ch 48 here yesterday. But ch 36 works also, today. Make sure you wait long enough for things to settle and come up. And check if you have to reconnect your AX client manually.
OE
Got it just came up...oddly enough, my ac laptop is at 160ghz..my note 20 U is AX capable but router picked up at 80ghz..interesting.
I'm curious about enabling DoS protection too. If enabling it increases CPU load as claimed, why would a home user enable it? I can understand why the NYTimes or Amazon may be subjected to Denial of Service attacks, but any one of the millions of home network users?This is your only configuration preference I would take exception to... I prefer to upgrade my network on my schedule when I have time to manage the interruption and any surprises for me and my users.
OE
Welcome To SNBForums
