RT-AX86U making audible noise
Kaver163
I have just bought a RT-AX86U which runs great but it does when using the 2,4 ghz band make high frequency electrical noise that I can hear several meters away. Since I have it in my living room it is distracting. When switching off the 2,4 GHz band and only using the 5 ghz band the router is however silent.
Anybody else having the same issue or are your RT-AX86Us silent?
That should be enough time to buy the replacement and test it before you send this one back. :)
Yes at first I wasn`t so happy with it as I also had some stability issues but after having now installed Merlin beta 4 these seem to have disappeared and speed, range, etc. is great, etc. so would like to stick with a (silent) AX86U ☺
Question is, does it drown out the wife?
