RT-AX86U - merlin: vlanctl throws unexpected errors
IgorZ
I was trying to setup a proper VLAN layout that would match my former network topology (ERX's + Ubiquity APs). I spent 3 full days reading though dozens of threads on this forum only to conclude: there is something REALLY NOT RIGHT about the `vlanctl` tool on my router. It's running the latest Merlin stable version (386.5_2). Yet, this tool throws errors in the cases that the other people on this forum suggest to use.
To name a few...
Bash:
vlanctl --rule-dump-all
No output. My router indeed have some rule. Including something that I've added right before running this command.
Bash:
vlanctl --if eth0 --rx --tags 0 --show-table
Throws an error no matter to what `if` or `tags` parameter value is set:
[ERROR vlanctl] vlanCtl_dumpRuleTable, 596: Invalid argument
There are more commands that don't pass through, even though there are posts on the forum about such the commands. I'm not posting all of them here since I feel there is something I miss in the root.
The real questions is: WHAT do I miss? Why are these commands run fine for the AC-86U router owners, but not for me (AX-86U owner)?
Moreover, in my device's syslog I discovered messages like:
Jun 5 22:54:34 kernel: ^[[0;33;41m[ERROR vlan] bcmVlan_dumpTagRules,2885: Real Device eth01--tx has no VLAN Interfaces
Jun 5 22:54:34 kernel: ^[[0;33;41m[ERROR vlan] vlanIoctl ,862: Failed to dump Rule Table from eth01--tx (tags=0, dir=-1)
Which implies the dump command is possible on my device. Just not from an SSH session in a form I'm trying to execute it.
A quick background on why do I need this tool to work. I'm trying to understand how is my system setup. I need it to properly adjust it to my needs. I've already tried NVRAM export tool. It's helpful, but doesn't give the answers I'm looking for.
To name a few...
Bash:
Bash:
Are you sure you didn't use "ip link" to create your VLANs?
