RT-AX86U Pro 388.1 networkmap: Error
lumia
Hello
at router RT-AX86U Pro (RT-AX86U_PRO_388.1_0_nand_squashfs.pkgtb)
without addons WITH usb stick installed
i have this msg
Jan 25 09:54:44 RT-AX86U_Pro networkmap: Error unlocking 8: 9 Bad file descriptor
Jan 25 09:54:44 RT-AX86U_Pro networkmap: Error unlocking 0: 9 Bad file descriptor
Jan 25 09:54:46 RT-AX86U_Pro networkmap: Error locking /var/lock//usr/networkmap/nmp_conv_type.js.lock: 2 No such file or directory
Jan 25 09:54:46 RT-AX86U_Pro networkmap: Error unlocking -1: 9 Bad file descriptor
Jan 25 09:54:46 RT-AX86U_Pro networkmap: Error locking /var/lock//usr/networkmap/nmp_vendor_type.js.lock: 2 No such file or directory
Jan 25 09:54:46 RT-AX86U_Pro networkmap: Error locking /var/lock//usr/networkmap/nmp_bwdpi_type.js.lock: 2 No such file or directory
The network map is closed source and beyond the control of RMerlin, if you can reproduce the problem on the stock firmware, you can report the bug to the official.
However, if the problem is just some logs that don't affect your normal use, maybe just ignoring them can save you time.
