RT-AX86U Pro - Browser Crash?
Neilistic
Hi All,
I've recently purchased this router and have just updated to the latest Asus firmware and think i have my system working ok for now.
I do have 1 strange thing that happens when I click from the System Log to Network Map and then back to System Log.
The web interface then seems only half load. I then refresh the page and there seems to be an error in the log - is this a concern?
Sep 24 09:45:32 kernel: CPU: 3 PID: 4032 Comm: httpd Tainted: P           O      4.19.183 #1
Sep 24 09:45:32 kernel: Hardware name: RTAX86U_PRO (DT)
Sep 24 09:45:32 kernel: pstate: 000f0010 (nzcv q A32 LE aif)
Sep 24 09:45:32 kernel: pc : 00000000f72f83a4
Sep 24 09:45:32 kernel: lr : 00000000fff8ab90
Sep 24 09:45:32 kernel: sp : 00000000fff8ab90
Sep 24 09:45:32 kernel: x12: 0000000000000000
Sep 24 09:45:32 kernel: x11: 00000000fff8ae20 x10: 00000000f73eef60
Sep 24 09:45:32 kernel: x9 : 0000000000000002 x8 : 0000000000000001
Sep 24 09:45:32 kernel: x7 : 00000000000000af x6 : 00000000fff8add0
Sep 24 09:45:32 kernel: x5 : 00000000fff8add0 x4 : 0000000000000006
Sep 24 09:45:32 kernel: x3 : 0000000000000008 x2 : 0000000000000000
Sep 24 09:45:32 kernel: x1 : 00000000fff8ab90 x0 : 0000000000000000
Sep 24 09:45:33 watchdog: start httpd
Sep 24 09:45:33 rc_service: watchdog 2581:notify_rc start_httpd
Sep 24 09:45:33 RT-AX86U_Pro: start httpd:80
Sep 24 09:48:16 kernel: CPU: 2 PID: 7360 Comm: httpd Tainted: P           O      4.19.183 #1
Sep 24 09:48:16 kernel: Hardware name: RTAX86U_PRO (DT)
Sep 24 09:48:16 kernel: pstate: 00070010 (nzcv q A32 LE aif)
Sep 24 09:48:16 kernel: pc : 00000000f713a3a4
Sep 24 09:48:16 kernel: lr : 00000000ff7f3080
Sep 24 09:48:16 kernel: sp : 00000000ff7f3080
Sep 24 09:48:16 kernel: x12: 0000000000000000
Sep 24 09:48:16 kernel: x11: 00000000ff7f3310 x10: 00000000f7230de0
Sep 24 09:48:16 kernel: x9 : 0000000000000002 x8 : 0000000000000001
Sep 24 09:48:16 kernel: x7 : 00000000000000af x6 : 00000000ff7f32c0
Sep 24 09:48:16 kernel: x5 : 00000000ff7f32c0 x4 : 0000000000000006
Sep 24 09:48:16 kernel: x3 : 0000000000000008 x2 : 0000000000000000
Sep 24 09:48:16 kernel: x1 : 00000000ff7f3080 x0 : 0000000000000000
Sep 24 09:48:33 watchdog: start httpd
Sep 24 09:48:33 rc_service: watchdog 2581:notify_rc start_httpd
Sep 24 09:48:33 RT-AX86U_Pro: start httpd:80
As a troubleshooting step, try a different web browser and or try a web browser on a different computer or device, if you haven't done so already to see if the issue persists.
Do you have any addon scripts installed? If so which one's?
As a last resort any time one has weird issues crop up. You could record all your settings, do a hard factory reset, then manual configuration (do not import a saved router.cfg file) of the router. If a USB hard drive is attached to the router, disconnect it prior to performing a hard factory reset and only reconnect it back to the router after the router has been completely reconfigured after the hard factory reset.
Not seeing a web browser issue going from System Log --> Network Map --> System Log on a RT-AX86U Pro running Asus-Merlin 3004.388.8_2. No errors in the log indicating an issue when going to from those pages.
Thank you for the reply.
I have tried accessing from my phone and another laptop and it does it there too.
I have just noticed the crash happens when clicking between the different menu options down the left side.
Currently im using the Asus firmware, I tried merlin yesterday but was having wifi connection issues so switched back. When using merlin, I did not have this specfic issue.
I will try the hard reset later.
