I've got 2 S21 Ultras and both have this issue. When arriving home, the phones will auto connect to the router most times without issue. Once in a while, I'll notice I'm not connected to wifi shortly after coming home and the phone will display "Connected without Internet". I don't have this issue with other devices, so I'm wondering if it isn't a phone problem. I read through a post on here and seen someone mentioned turning off Roaming Assistant. Do you think this would help in anyway? My thinking is maybe the signal isn't strong enough when I pull in my driveway when my phone tries to connect.
I've gone through my wifi history log on my phone and it shows an entry labeled "ASSOC_REJECT" with reason code 1026. The timestamp on it was when I arrived at home so this must be something related to the problem. I have no idea what the reason code is for. Can't find anything on Google about it.
