Trippie123
Hey,
The fix for this is probably simple but I can't figure it out. I've hooked up the Asus router to my ISP modem with DMZ enabled towards the router.
When I turn off the IPv6 firewall in the Asus settings, IPv6 works fine. When it's turned on it stops working. I tried opening port 546 UDP which doesn't really help.
Anyone knows the solution? Do I even need the Asus firewall or does the modem have one anyway? If so, can I test it. If I understand DMZ correctly it would bypass the firewall right?
Thanks in advance.
Edit: I just figured out that I can disable the DMZ IPv6 on the modem so then I can also disable the firewall on the router. It would be nice though if anyone knows a way to let the Asus router handle the firewall?
Thanks in advance.
