I set up a new RT-AX86U last weekend and I'm making changes to the basic setup and learning to find my way around the router. Using Merlin 386.2_4.
I'd successfully setup a VPN client and directed 2 devices with fixed IPs to use the tunnel through the routing panel at the bottom of the VPN client page. All worked as expected.
I now need to stop one of devices, a windows laptop, from using the tunnel and connect through the WAN. I turned off the VPN connection and removed the laptop from the routing panel at the bottom of the VPN page, saved the setting which then showed the laptop removed and VPN turned off. I restarted the laptop but could not connect to the WAN (WiFi connected), I restarted the router and laptop but still no joy.
If I look in the system log I see the following which I assume is the problem: (The MAC address was that of the laptop.)
Can anyone help sort this out?
I've now turned the VPN back on without the rule telling the laptop to use the VPN and the laptop now connects to the internet using the WAN which is what I want but there is a problem somewhere, I assume the blocking if VPN down rule or policy rule is still being applied to the laptop even though it's not using the VPN.May 28 11:20:18 kernel: CONSOLE: 339948.973 wl1.0: wlc_send_bar: for aa:bb:cc:dd:ee:ff seq 0x1 tid 4
May 28 11:20:18 kernel: CONSOLE: 339949.135 wl1.0: wlc_send_bar: for aa:bb:cc:dd:ee:ff seq 0x1 tid 2
May 28 11:20:38 kernel: CONSOLE: 339968.453 wl1.0: wlc_send_bar: for aa:bb:cc:dd:ee:ff seq 0x1 tid 3
