Sparkytech
Hello,
First off I would like to say hello new to this forum but have done a lot of research on this forum for answers and more. Thanks
So here we go, I have a RT-AX86u running as my primary router, I have 2 RT-AC68U's running as wired access points off the primary router the AX86u.
The other day I could not log into the primary router the AX86U. So I had to do a hard reset.
Once I did the hard reset my wifi light never came back on but on the router homepage showed it running as normal with the correct SSID.
So tried to use the recovery rescue software from Asus still didn't work.
So after a lot of messing around found by looking in my log that my MTD10 partition was not present.
I read on other threads in the forum this has happened to others and mention someone who could maybe sort it out. I however decide to buy another router. We'll that was the plan.
Decided to set the AX86u up again this time after I setup the wireless information and the SSID I disabled both the 2.4ghz and the 5ghz wifi radios. I the connected my access points backup to the AX86U. Surprisingly everything worked with the wifi disabled on the AX86U. What I don't understand is why?
When you set up access points you match everything to the primary router except the wifi channels need to be different but if the wifi doesn't work as in my case how do the access points work? I also was very impressed the primary router wasn't so stressed as it was when the wifi worked. I would see spikes go really high where at some points the memory was maxed out. Any feedback would be great.
Also forgot to mention currently running Merlin RT-AX86U_3004_388.8_2.
