RT-AX88U Cooling Direction
you didn't encounter dust problem as its been an year you're using cooling pad for the purpose
by the way, koooooooooool temperatures :cool:
No because once a quarter I use a can of compressed air on all my computer equipment. If you don't regularly clean then I can see it being an issue.
ax88 running wide open... it can be done...
@immi803 I'm guessing 'naked', but not 'unplugged'. :)
Can you share picture of this wide open thingy
Shocked at your temperatures
as I said in an earlier post here - two, 60cfm fans (140mm - blowing up) under each of them... 'wide open' was referring to routing with scripts running...
What is the ambient temp where you are?
