RT-AX88U losing WIFI
duri3
Since a few weeks, my Asus RT-AX88U sometimes drops WIFI.
Usually it comes back, after reboot the router or press the wifi button twice to disable and enable it again, wifi clients see the wifi network again and connect.
I already tried different merlin firmware. Also I did reset the router and reenter all setting manuel without backup. Nothing seems to really help.
Is this a hardware issue?
Logs down there:
Sep  6 13:02:35 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind B2:75:D0:09:9B:A6, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-69
Sep  6 13:02:35 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind B2:75:D0:09:9B:A6, status: 0, reason: Previous authentication no longer valid (2), rssi:-69
Sep  6 13:02:41 wlceventd: wlceventd_proc_event(685): eth7: Auth B2:75:D0:09:9B:A6, status: Successful (0), rssi:0
Sep  6 13:02:41 wlceventd: wlceventd_proc_event(722): eth7: Assoc B2:75:D0:09:9B:A6, status: Successful (0), rssi:-69
Sep  6 13:06:20 wlceventd: wlceventd_proc_event(685): eth7: Auth 52:2E:C9:6F:88:30, status: Successful (0), rssi:0
Sep  6 13:06:20 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 52:2E:C9:6F:88:30, status: Successful (0), rssi:-77
Sep  6 13:17:37 wlceventd: wlceventd_proc_event(685): eth7: Auth 86:FF:17:75:79:47, status: Successful (0), rssi:0
Sep  6 13:17:37 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 86:FF:17:75:79:47, status: Successful (0), rssi:-81
Sep  6 13:24:50 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 86:FF:17:75:79:47, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-71
Sep  6 13:24:51 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 86:FF:17:75:79:47, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep  6 13:25:50 wlceventd: wlceventd_proc_event(685): eth7: Auth 02:9F:EB:96:C5:62, status: Successful (0), rssi:0
Sep  6 13:25:50 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 02:9F:EB:96:C5:62, status: Successful (0), rssi:-58
Sep  6 13:27:13 wlceventd: wlceventd_proc_event(685): eth7: Auth 86:FF:17:75:79:47, status: Successful (0), rssi:0
Sep  6 13:27:13 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 86:FF:17:75:79:47, status: Successful (0), rssi:-53
Sep  6 13:32:03 wlceventd: wlceventd_proc_event(685): eth7: Auth 02:9F:EB:96:C5:62, status: Successful (0), rssi:0
Sep  6 13:32:03 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 02:9F:EB:96:C5:62, status: Successful (0), rssi:-56
Sep  6 13:32:31 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 86:FF:17:75:79:47, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-75
Sep  6 13:32:32 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 86:FF:17:75:79:47, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep  6 13:59:11 wlceventd: wlceventd_proc_event(685): eth7: Auth 40:BC:60:A4:CE:8B, status: Successful (0), rssi:0
Sep  6 13:59:11 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 40:BC:60:A4:CE:8B, status: Successful (0), rssi:-72
Sep  6 13:59:15 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 40:BC:60:A4:CE:8B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-71
Sep  6 13:59:15 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 40:BC:60:A4:CE:8B, status: 0, reason: Previous authentication no longer valid (2), rssi:-71
Sep  6 13:59:20 wlceventd: wlceventd_proc_event(685): eth7: Auth 40:BC:60:A4:CE:8B, status: Successful (0), rssi:0
Sep  6 13:59:20 wlceventd: wlceventd_proc_event(722): eth7: Assoc 40:BC:60:A4:CE:8B, status: Successful (0), rssi:-70
Sep  6 13:59:20 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 40:BC:60:A4:CE:8B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep  6 14:13:35 wlceventd: wlceventd_proc_event(685): eth7: Auth F0:A3:5A:5D:90:A5, status: Successful (0), rssi:0
Sep  6 14:13:35 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc F0:A3:5A:5D:90:A5, status: Successful (0), rssi:-63
Sep  6 14:14:14 wlceventd: wlceventd_proc_event(685): eth7: Auth 40:BC:60:A4:CE:8B, status: Successful (0), rssi:0
Sep  6 14:14:14 wlceventd: wlceventd_proc_event(722): eth7: Assoc 40:BC:60:A4:CE:8B, status: Successful (0), rssi:-81
Sep  6 14:50:55 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 52:2E:C9:6F:88:30, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep  6 14:51:01 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind C8:69:CD:6E:09:EA, status: 0, reason: Unspecified reason (1), rssi:0
Sep  6 14:51:01 wlceventd: wlceventd_proc_event(685): eth7: Auth C8:69:CD:6E:09:EA, status: Successful (0), rssi:0
Sep  6 14:51:02 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind C8:69:CD:6E:09:EA, status: 0, reason: Unspecified reason (1), rssi:0
Sep  6 14:51:02 wlceventd: wlceventd_proc_event(685): eth7: Auth C8:69:CD:6E:09:EA, status: Successful (0), rssi:0
Sep  6 14:56:24 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind C8:69:CD:6E:09:EA, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep  6 14:56:25 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind C8:69:CD:6E:09:EA, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Sep  6 15:04:51 wlceventd: wlceventd_proc_event(685): eth7: Auth 40:BC:60:A4:CE:8B, status: Successful (0), rssi:0
Sep  6 15:04:51 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc 40:BC:60:A4:CE:8B, status: Successful (0), rssi:-73
Sep  6 15:04:55 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 40:BC:60:A4:CE:8B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-73
Sep  6 15:04:56 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 40:BC:60:A4:CE:8B, status: 0, reason: Previous authentication no longer valid (2), rssi:-73
Sep  6 15:38:02 wlceventd: wlceventd_proc_event(685): eth6: Auth 60:74:F4:2D:CF:6E, status: Successful (0), rssi:0
Sep  6 15:38:02 wlceventd: wlceventd_proc_event(722): eth6: Assoc 60:74:F4:2D:CF:6E, status: Successful (0), rssi:-47
Sep  6 15:48:57 wlceventd: wlceventd_proc_event(685): eth6: Auth B4:60:ED:01:89:D1, status: Successful (0), rssi:0
Sep  6 15:48:57 wlceventd: wlceventd_proc_event(722): eth6: Assoc B4:60:ED:01:89:D1, status: Successful (0), rssi:-67
Sep  6 15:53:52 wlceventd: wlceventd_proc_event(685): eth7: Auth F0:A3:5A:5D:90:A5, status: Successful (0), rssi:0
Sep  6 15:53:53 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind F0:A3:5A:5D:90:A5, status: 0, reason: Unspecified reason (1), rssi:0
Sep  6 15:53:53 wlceventd: wlceventd_proc_event(685): eth7: Auth F0:A3:5A:5D:90:A5, status: Successful (0), rssi:0
Sep  6 15:53:54 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind F0:A3:5A:5D:90:A5, status: 0, reason: Unspecified reason (1), rssi:0
Logs down there:
What's your current setup i.e. using smartconnect or separate bands (is it 2.4ghz or 5ghz band that drop WiFi or both)? Are you using AiMesh?
When was the last time you did a factory reset? When it does drop go to System log tab-- Wireless log and check if the radios (2.4 & 5ghz) are showing up. If they're not showing or only 1 shows up, it can be a potential hardware failure.
My setup is rather simple.
I use separate Bands and no AiMesh.
Last factory reset was 2 weeks ago. The issues started a few weeks before.
I will try to check the wireless log next time the problem occurs.
Show us screenshots of your Wi-Fi settings.
I'm using Merlin for many year and never had problem with my settings.
Thank you will try those settings. But just to be clear. The issue is not clients dropping the wifi. The issue is the router stops the wifi signal. There is no wifi connection or wifi network sometimes. Clients not finding the SSID even if I scan for them. So its look like a wifi driver or hardware issue from the rt-ax88u.
After updating to latest Asuswrt-Merlin? If yes - revert to previous 386.7 version and see how it goes. There are reports of Wi-Fi issues from other forum members as well. Check the release thread.
Yes I think all started with 388.8 before it was rock stable. That's why I also did a factory reset but the problem is not solved. I guess it's downgrade to 388.7 too for me. Is WIFI stable for you again after downgrading?
Sorry, I don't have any Asus routers in use. I have a few available Asus routers used for testing purposes only and what happens after a week or two uptime - I don't know.
I downgraded to 388.7 last Friday. The problem has not occurred since then. There is no longer a single entry in the log saying "status: 0, reason: Unspecified reason (1), rssi:0".
Hi there.
I too am experiencing these same issues but on a new AX86U Pro.
Some of my devices are dropping connection on the wifi and re-connecting a few moments later.
Most of the devices have been connected for many many hours but a few seem to keep dropping and reconnecting such as my android phone.
My log is filled with messages such as "wlceventd" and Previous authentication no longer valid (2), rssi:-63 which coincide with the wifi drop on the device.
Has reverting back to the previous firmware still resolved your issues? If so, I may try the same.
Sep 23 11:37:48 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth6 ssid c8:7f:54:7b:94:90
Sep 23 11:37:49 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=a0, status=7, mac=00:00:00:00:00:00
Sep 23 11:37:49 bsd: bsd: BSS Transit Response: STA reject
Sep 23 11:37:49 bsd: bsd: Skip STA:b6:ce:51:12:5b:d2 reject BSSID
Sep 23 11:43:55 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth6 ssid c8:7f:54:7b:94:90
Sep 23 11:43:56 bsd: bsd: STA:b6:ce:51:12:5b:d2 no response
Sep 23 11:43:56 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth6 ssid c8:7f:54:7b:94:90
Sep 23 11:43:56 wlceventd: wlceventd_proc_event(685): eth6: Auth B6:CE:51:12:5B:D2, status: Successful (0), rssi:0
Sep 23 11:43:56 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc B6:CE:51:12:5B:D2, status: Successful (0), rssi:-62
Sep 23 11:43:56 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=a1, status=0, mac=c8:7f:54:7b:94:90
Sep 23 11:43:56 bsd: bsd: BSS Transit Response: not for token a2
Sep 23 11:43:56 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind B6:CE:51:12:5B:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-83
Sep 23 11:43:56 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind B6:CE:51:12:5B:D2, status: 0, reason: Disassociated due to inactivity (4), rssi:-83
Sep 23 11:47:47 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth7 ssid c8:7f:54:7b:94:94
Sep 23 11:47:48 bsd: bsd: STA:b6:ce:51:12:5b:d2 no response
Sep 23 11:47:48 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth7 ssid c8:7f:54:7b:94:94
Sep 23 11:47:48 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=a4, status=7, mac=00:00:00:00:00:00
Sep 23 11:47:48 bsd: bsd: BSS Transit Response: STA reject
Sep 23 11:47:48 bsd: bsd: Skip STA:b6:ce:51:12:5b:d2 reject BSSID
Sep 23 11:51:59 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth7 ssid c8:7f:54:7b:94:94
Sep 23 11:51:59 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=a5, status=7, mac=00:00:00:00:00:00
Sep 23 11:51:59 bsd: bsd: BSS Transit Response: STA reject
Sep 23 11:51:59 bsd: bsd: Skip STA:b6:ce:51:12:5b:d2 reject BSSID
Sep 23 11:56:25 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth7 ssid c8:7f:54:7b:94:94
Sep 23 11:56:26 bsd: bsd: STA:b6:ce:51:12:5b:d2 no response
Sep 23 11:56:26 bsd: bsd: Sending act Frame to b6:ce:51:12:5b:d2 with transition target eth7 ssid c8:7f:54:7b:94:94
Sep 23 11:56:27 bsd: bsd: STA:b6:ce:51:12:5b:d2 no response
Sep 23 11:56:27 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind B6:CE:51:12:5B:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Sep 23 11:56:28 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind B6:CE:51:12:5B:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Sep 23 11:59:40 wlceventd: wlceventd_proc_event(685): eth6: Auth B6:CE:51:12:5B:D2, status: Successful (0), rssi:0
Sep 23 11:59:40 wlceventd: wlceventd_proc_event(722): eth6: Assoc B6:CE:51:12:5B:D2, status: Successful (0), rssi:-63
this is being caused by mac randomization, for very particular models of android phones.
noted the S24's and 23's so far, hasn't replicated with S21's or 20's.
it may be a problem with the android dhcp client service on these models.
Hi there.
Hi
My Devices had no single drop after I have reverting back to the previous firmware 388.7. It's stable as it's used to be :)
Thank you for the reply.
I do have an S23 Ultra and my parter has an S24 Plus and both appear do disconnect and reconnect throughout the days.
Is it the phones or the Asus Router thats the issue?
Until last week I had the Asus RT-AC86U and dont believe we had this issue.
Is there anything i can do to stop the issue?
There have been no changes to the wifi drivers between 388.7 and 388.8. What you may be seeing is purely coincidental.
Point to note - myself and a few others have had to factory reset moving to the 388.8 for stability. A reset is a valid diagnostic tool.
