RT-AX88U New official firmware Version 3.0.0.4.384.7977
Toink
Version 3.0.0.4.384.7977 2020/02/2070.81 MBytes
ASUS RT-AX88U Firmware version 3.0.0.4.384.7977
- Improve stability.
- Fixed some internet disconnect issues.
Please unzip the firmware file first then check the MD5 code.
MD5: bac195fd6ba492cb14e661427bcaa4bc
Is there any need to make a full factory reset after the upgrade (I've got 1st AX88U as main router and 2nd AX88U as AP in AiMesh via ethernet cable).
Thank you
@gpmc not if your network and router are behaving as you expect. :)
For me, exact same problem as the 7968. All devices connected loose internet connection and you can’t connect any new device to WiFi. Even LAN connection stop working. I’m back to 7756...
I'm curious about your settings. What devices get disconnected. Updated drivers on those devices? Full factory reset after updating to this firmware?
I'm not being discourteous. I believe more detailed info is more helpful to everyone.
I have the same problems as xha1000. Works for a while then devices disconnect, also if you connect a wired device it dose not get an ip.
Feb 21 08:31:58 rc_service: cfg_server 1374:notify_rc stop_upgrade;start_webs_download
Feb 21 08:31:58 usb: USB is ejected
Feb 21 08:31:58 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 21 08:31:59 BWDPI: force to flush flowcache entries
May 5 01:05:08 kernel: brcmboard registered
May 5 01:05:08 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May 5 01:05:08 kernel: gluebi (pid 1): gluebi_resized: got update notification for unknown UBI device 0 volume 0
May 5 01:05:08 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:08 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:08 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:08 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:08 kernel: broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
May 5 01:05:08 kernel: eth5 (Ext switch port: 7) (Logical Port: 15) (phyId: 1e) Link UP at 1000 mbps full duplex
May 5 01:05:08 nat: apply redirect rules
May 5 01:05:12 RT-AX88U: start https:8443
May 5 01:05:12 RT-AX88U: start httpd:80
May 5 01:05:13 WAN Connection: Ethernet link down.
May 5 01:05:21 NAT Tunnel: AAE Service is stopped
May 5 01:05:21 AAE: AAE Service is started
May 5 01:05:21 disk monitor: be idle
May 5 01:05:21 hour monitor: daemon is starting
May 5 01:05:21 jffs2: valid logs(1)
May 5 01:05:21 Mastiff: init
May 5 01:05:21 ERP: The model isn't under EU SKU!
May 5 01:05:22 BONDING: option disabled
May 5 01:05:29 modprobe: module ledtrig-usbdev not found in modules.dep
May 5 01:05:29 modprobe: module leds-usb not found in modules.dep
May 5 01:05:29 modprobe: module scsi_wait_scan not found in modules.dep
May 5 01:05:29 modprobe: module mbcache not found in modules.dep
May 5 01:05:29 modprobe: module jbd not found in modules.dep
May 5 01:05:29 modprobe: module ext3 not found in modules.dep
May 5 01:05:29 modprobe: module ext4 not found in modules.dep
May 5 01:05:29 modprobe: module ext2 not found in modules.dep
May 5 01:05:29 modprobe: module btusbdrv not found in modules.dep
May 5 01:05:30 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
May 5 01:05:33 WAN Connection: ISP's DHCP did not function properly.
May 5 01:05:53 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
May 5 01:05:53 wan: finish adding multi routes
May 5 01:05:54 WAN Connection: WAN was restored.
May 5 01:05:56 ntp: start NTP update
Feb 21 08:34:21 rc_service: ntp 1879:notify_rc restart_diskmon
Feb 21 08:34:21 disk_monitor: Finish
Feb 21 08:34:21 disk monitor: be idle
Feb 21 08:34:21 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 08:34:21 ddns update: ez-ipupdate: starting...
Feb 21 08:34:21 ddns update: asus_private() interface =eth0
Feb 21 08:34:21 ddns update: g_asus_ddns_mode == 2
Feb 21 08:34:22 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Feb 21 08:34:22 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 21 Feb 2020 13:34:20 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 08:34:22 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 08:34:22 ddns update: asusddns_update: 0
Feb 21 08:34:22 ddns: ddns update ok
Feb 21 08:34:22 ddns update: exit_main
Feb 21 08:34:25 crond[1164]: time disparity of 946589 minutes detected
Feb 21 08:34:30 rc_service: udhcpc 1777:notify_rc start_dnsmasq
Feb 21 08:34:34 BWDPI: fun bitmap = 47f
Feb 21 08:34:36 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 21 08:34:36 dhcp client: bound 173.76.111.98/255.255.255.0 via 173.76.111.1 for 7200 seconds.
Feb 21 08:34:37 watchdog: start ddns.
Feb 21 08:34:37 rc_service: watchdog 1170:notify_rc restart_ddns
Feb 21 08:34:37 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 08:34:37 ddns update: ez-ipupdate: starting...
Feb 21 08:34:37 ddns update: asus_private() interface =eth0
Feb 21 08:34:37 ddns update: g_asus_ddns_mode == 2
Feb 21 08:34:37 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Feb 21 08:34:38 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 21 Feb 2020 13:34:36 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 08:34:38 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 08:34:38 ddns update: asusddns_update: 0
Feb 21 08:34:38 ddns: ddns update ok
Feb 21 08:34:38 ddns update: exit_main
Feb 21 08:35:37 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6148)]period_retry = 0
Feb 21 08:35:37 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6154)]periodic_check AM 4:41
Feb 21 08:35:37 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6177)]retrieve firmware information
Feb 21 08:35:37 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6193)]no need to upgrade firmware
Feb 21 08:35:40 rc_service: rc 3036:notify_rc restart_wrs
Feb 21 08:35:43 BWDPI: fun bitmap = 47f
Feb 21 08:35:46 hour monitor: ntp sync fail, will retry after 120 sec
Feb 21 09:00:21 disk_monitor: Got SIGALRM...
Feb 21 09:30:37 httpd login lock: Detect abnormal logins at 5 times. The newest one was from 74.208.28.145 in login.
Feb 21 14:57:52 rc_service: httpds 1165:notify_rc restart_firewall
Feb 21 14:57:52 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 21 14:58:01 rc_service: httpds 1165:notify_rc restart_firewall;restart_wrs
Feb 21 14:58:01 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 21 14:58:04 BWDPI: fun bitmap = 57f
May 5 01:05:07 kernel: brcmboard registered
May 5 01:05:07 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May 5 01:05:07 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:07 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:07 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:07 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 01:05:07 kernel: broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
May 5 01:05:07 kernel: eth5 (Ext switch port: 7) (Logical Port: 15) (phyId: 1e) Link UP at 1000 mbps full duplex
May 5 01:05:07 nat: apply redirect rules
May 5 01:05:11 RT-AX88U: start https:8443
May 5 01:05:11 RT-AX88U: start httpd:80
May 5 01:05:20 NAT Tunnel: AAE Service is stopped
May 5 01:05:20 AAE: AAE Service is started
May 5 01:05:20 disk monitor: be idle
May 5 01:05:20 hour monitor: daemon is starting
May 5 01:05:20 jffs2: valid logs(1)
May 5 01:05:20 Mastiff: init
May 5 01:05:20 ERP: The model isn't under EU SKU!
May 5 01:05:21 BONDING: option disabled
May 5 01:05:27 modprobe: module ledtrig-usbdev not found in modules.dep
May 5 01:05:27 modprobe: module leds-usb not found in modules.dep
May 5 01:05:27 modprobe: module scsi_wait_scan not found in modules.dep
May 5 01:05:27 modprobe: module mbcache not found in modules.dep
May 5 01:05:27 modprobe: module jbd not found in modules.dep
May 5 01:05:27 modprobe: module ext3 not found in modules.dep
May 5 01:05:27 modprobe: module ext4 not found in modules.dep
May 5 01:05:27 modprobe: module ext2 not found in modules.dep
May 5 01:05:27 modprobe: module btusbdrv not found in modules.dep
May 5 01:05:28 WAN Connection: ISP's DHCP did not function properly.
May 5 01:05:28 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
May 5 01:05:29 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
May 5 01:05:29 wan: finish adding multi routes
May 5 01:05:33 WAN Connection: WAN was restored.
May 5 01:05:35 ntp: start NTP update
Feb 21 16:27:32 rc_service: ntp 1757:notify_rc restart_diskmon
Feb 21 16:27:32 disk_monitor: Finish
Feb 21 16:27:32 disk monitor: be idle
Feb 21 16:27:32 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 16:27:32 ddns update: ez-ipupdate: starting...
Feb 21 16:27:32 ddns update: asus_private() interface =eth0
Feb 21 16:27:32 ddns update: g_asus_ddns_mode == 2
Feb 21 16:27:32 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Feb 21 16:27:33 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 21 Feb 2020 21:27:32 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 16:27:33 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 16:27:33 ddns update: asusddns_update: 0
Feb 21 16:27:33 ddns: ddns update ok
Feb 21 16:27:33 ddns update: exit_main
Feb 21 16:27:38 watchdog: start ddns.
Feb 21 16:27:38 rc_service: watchdog 1167:notify_rc restart_ddns
Feb 21 16:27:38 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 16:27:38 ddns update: ez-ipupdate: starting...
Feb 21 16:27:38 ddns update: asus_private() interface =eth0
Feb 21 16:27:38 ddns update: g_asus_ddns_mode == 2
Feb 21 16:27:38 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Feb 21 16:27:39 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 21 Feb 2020 21:27:38 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 16:27:39 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 16:27:39 ddns update: asusddns_update: 0
Feb 21 16:27:39 ddns: ddns update ok
Feb 21 16:27:39 ddns update: exit_main
Feb 21 16:27:41 rc_service: udhcpc 1655:notify_rc start_dnsmasq
Feb 21 16:27:44 BWDPI: fun bitmap = 57f
Feb 21 16:27:47 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 21 16:27:47 dhcp client: bound 173.76.111.98/255.255.255.0 via 173.76.111.1 for 7200 seconds.
Feb 21 16:27:56 crond[1161]: time disparity of 947062 minutes detected
These details should ALWAYS be posted to get a better idea of what could be wrong:
1. From which firmware BEFORE the upgrade.
2. Did you do a FULL factory restore AFTER the upgrade?
3. How are you connected to the internet?
Pretty much: What have you done so far?
clean install from previous firmware 7968 that had no problems and 20+ days of uptime
For those experiencing connection issues did you give enough time for the AX88U to come back up and its connection to the device its connected to for WAN? For me after the update was finished it took a short time to establish connection to my cable modem. Brief look at the logs here I do not see anything glaring as an issue.
This set of logs is from 5 hrs after upgrade, for no reason WiFi was not allowing new devices and wired did not provide a DCHP.
"I am on the latest ASUS firmware. The router is still quite unstable and drops connections, loses WiFi with clients and needs to be rebooted often. I have temporarily changed back to my ac310"
@brianmsailing... I went back over your posts dating back to June 2019 which seem to me you are having the same issue with this build as you did with prior ones. It seems somewhere along the line it was resolved yet came back?
Sorry guys, I didn’t put the log because it says nothing unusual, I’ve to put it in notice mode to get more details...
but I’ve 50 devices, thermostat, light switch, tv, etc. Most of them are on the 2.4ghz. I use PPOE with vlan tagging for WAN. Router is set a OpenVPN server but nothing else.
Everything OK since 7968.
I will retry with factory reset and logging details soon...
latest logs after going back to 6436, something is still not right. Lots of BWDPI events.
Feb 21 23:26:12 rc_service: ntp 1779:notify_rc restart_diskmon
Feb 21 23:26:12 disk_monitor: Finish
Feb 21 23:26:12 disk monitor: be idle
Feb 21 23:26:12 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 23:26:12 ddns update: ez-ipupdate: starting...
Feb 21 23:26:12 ddns update: asus_private() interface =eth0
Feb 21 23:26:12 ddns update: g_asus_ddns_mode == 2
Feb 21 23:26:12 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 21 23:26:13 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 22 Feb 2020 04:26:12 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 23:26:13 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 23:26:13 ddns update: asusddns_update: 0
Feb 21 23:26:13 ddns: ddns update ok
Feb 21 23:26:13 ddns update: exit_main
Feb 21 23:26:17 watchdog: start ddns.
Feb 21 23:26:17 rc_service: watchdog 1109:notify_rc restart_ddns
Feb 21 23:26:17 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 23:26:17 ddns update: ez-ipupdate: starting...
Feb 21 23:26:17 ddns update: asus_private() interface =eth0
Feb 21 23:26:17 ddns update: g_asus_ddns_mode == 2
Feb 21 23:26:17 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 21 23:26:18 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 22 Feb 2020 04:26:17 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 23:26:18 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 23:26:18 ddns update: asusddns_update: 0
Feb 21 23:26:18 ddns: ddns update ok
Feb 21 23:26:18 ddns update: exit_main
Feb 21 23:26:21 rc_service: udhcpc 1672:notify_rc start_dnsmasq
Feb 21 23:26:21 dhcp client: bound 173.76.111.98/255.255.255.0 via 173.76.111.1 for 7200 seconds.
Feb 21 23:26:37 crond[1103]: time disparity of 947481 minutes detected
Feb 21 23:27:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6099)]period_retry = 0
Feb 21 23:27:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6105)]periodic_check AM 3:5
Feb 21 23:27:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6128)]retrieve firmware information
Feb 21 23:27:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6131)]user in use
Feb 21 23:30:06 rc_service: httpd 1105:notify_rc restart_ddns_le
Feb 21 23:30:06 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 21 23:30:06 ddns update: ez-ipupdate: starting...
Feb 21 23:30:06 ddns update: asus_private() interface =eth0
Feb 21 23:30:06 ddns update: g_asus_ddns_mode == 2
Feb 21 23:30:06 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 21 23:30:07 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 22 Feb 2020 04:30:07 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 21 23:30:07 ddns update: retval= 0, ddns_return_code (,200)
Feb 21 23:30:07 ddns update: asusddns_update: 0
Feb 21 23:30:07 ddns: ddns update ok
Feb 21 23:30:07 ddns update: exit_main
Feb 21 23:40:00 rc_service: service 3030:notify_rc restart_letsencrypt
Feb 21 23:59:00 rc_service: service 3555:notify_rc restart_letsencrypt
Feb 22 00:00:12 disk_monitor: Got SIGALRM...
Feb 22 00:15:46 httpd login lock: Detect abnormal logins at 5 times. The newest one was from 74.208.28.145 in login.
Feb 22 03:05:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6099)]period_retry = 1
Feb 22 03:05:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6128)]retrieve firmware information
Feb 22 03:05:17 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6144)]no need to upgrade firmware
Feb 22 03:05:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6099)]period_retry = 2
Feb 22 03:05:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6128)]retrieve firmware information
Feb 22 03:05:47 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6144)]no need to upgrade firmware
Feb 22 07:00:47 BWDPI: fun bitmap = 3
Feb 22 07:01:05 BWDPI: force to flush flowcache entries
Feb 22 07:01:05 BWDPI: rollback fc
Feb 22 07:01:05 rc_service: bwdpi_check 1276:notify_rc start_firewall
Feb 22 07:01:05 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 22 12:30:00 rc_service: service 23293:notify_rc restart_letsencrypt
Feb 22 12:31:00 rc_service: service 23378:notify_rc restart_letsencrypt
Feb 22 12:40:00 rc_service: service 23645:notify_rc restart_letsencrypt
Feb 22 12:59:00 rc_service: service 24197:notify_rc restart_letsencrypt
Feb 22 13:48:24 BWDPI: fun bitmap = 3
Feb 22 13:49:07 BWDPI: force to flush flowcache entries
Feb 22 13:49:07 BWDPI: rollback fc
Feb 22 13:49:07 rc_service: bwdpi_check 1276:notify_rc start_firewall
Feb 22 13:49:07 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 22 13:49:22 BWDPI: fun bitmap = 3
Feb 22 13:50:02 BWDPI: force to flush flowcache entries
Feb 22 13:50:02 BWDPI: rollback fc
Feb 22 13:50:02 rc_service: bwdpi_check 1276:notify_rc start_firewall
Feb 22 13:50:02 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
