Ben Perkins
Over the holidays I finally took the plunge on upgrading my wireless network. I retired my old RT-N66Rs (also running Merlin) and and replaced them with an RT-AX88U (running Merlin 386.1_beta3 ) working as the main router, and then a RP-AC1900 (running stock 3.0.0.4.385_20630-ged5e4c3) serving as an AiMesh node to give me better coverage at the back of the house.
Overall, the solution is working great. Unfortunately, I did have an old issue with parental controls resurface though. When the time based controls for a given device kick in, new connections are blocked, but existing connections are not blocked (e.g. a Roku device that's streaming Netflix can keep on going for hours after the time when the controls are applied).
With older devices, there was a recommendation in the UI to disable NAT acceleration in order to make Time Scheduling work better. But with the AX88U, the recommendation has disappeared from the Parental Controls UI, and the option has disappeared entirely from the LAN->Switch Control section of the UI.
I've searched the forums and found:
- One thread confirming the option doesn't exist anymore: https://www.snbforums.com/threads/asus-ax88u-nat-acceleration-option.66145/
- One thread where @sturmstar indicates his AX88U parental controls work fine even with NAT acceleration on: https://www.snbforums.com/threads/p...on-for-more-precise-scheduling-control.63377/
Are others with AX88U seeing Time Scheduling work properly for existing connections? If so, can you give more information on what configuration options you have set?
Alternatively, can anyone suggest workarounds for this issue? For the moment I'm making use of the router reboot time scheduler to make sure no existing connections persist beyond midnight, but that's a little more brute force than I'd like.
Many thanks for any help or suggestions.
Ben
Ben
