Hello. Been using this router solid on Virgin Media for about a year. I’ve now switched to CityFibre on Vondafone Gigafast plan using my RT-AX88U. Had to manually configure the pppoe with supplied username and password, and also have to add an IPTV value to make it work, unsure why but then authenticates and get good speeds. HOWEVER, the router drops out on average once a day, get red light on front of router and the pppoe has deauthed. The separate fibre modem is always healthy green lights. The only way to restore internet service is to reboot the ASUs router.
Vodafone have check the line and all is good, internet service remains constant if I use their supplier router. It’s driving me nuts!
I’m running the latest Merlin firmware 386.5 and have done a full factory reset before applying the new firmware. I read some old posts suggesting to spoof MAC address, tried that be didn’t work
Any help or advise welcome, Here’s what I get in the logs
Deauth_ind macaddress, status: 0, reason: Unspecified reason (1)
Deauth_ind macaddress, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Disassoc macaddress, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
