RT-AX88U Pro & RT-AC66U B1 Issues Aimesh Config
elrengo
Hi! I have both routers and I want to set up my second router, the RT-AC66U B1, as an AiMesh node. The RT-AX88U Pro found it and started setting up. The process has been interrupted and therefore has not been completed, leaving the router RT-AC66U B1 unable to finish the boot-up process. The power light keeps blinking continuously. I have tried, as indicated on the website, (https://www.asus.com/support/faq/1000925/) holding down the reset button for 10 seconds, but it doesn't work. I've also tried turning it off, pressing the button, waiting 30 seconds, turning it back on while continuing to hold the button, but it still behaves the same way.
If you can get it working again (ASUS recovery utility?), I would put current ASUSWRT firmware on it and Hard Reset before trying to add it as node.
OE
Thanks! The router is working after shutdown a few minutes can start perfectly and now is a node in my network.
