Solved RT-AX88U Pro Unable to connect to Wifi
fotingo
I was able to get my hands on the AX88U Pro. Before installing the Merlin firmware, I wanted to test out the router.
I notice when creating a guest network or IoT network, if I uncheck that option that says "Use same subnet as main network", I doesn't allow me to connect to that wifi network at all.
The iphone just spins and spins and never connects. But, If I leave it checked, then it connects right away.
Does that mean I can't create a guest network or IoT network on a different subnet?
