i am running 41700 firmware for a while now(did a clean setup, no config restores)
now i experienced something what looks like a WAN reset which happened a couple of times in a row.
googling the error shows that this might be an old bug reappearing again.
anbody knows what is happening
i do not have services like vpn running.
I do have ddns enabled
Feb 4 16:35:02 rc_service: httpd 1336:notify_rc restart_net_and_phy
Feb 4 16:35:04 iTunes: daemon is stoped
Feb 4 16:35:04 FTP Server: daemon is stoped
Feb 4 16:35:04 Samba Server: smb daemon is stoped
Feb 4 16:35:10 kernel: eth5 (Ext switch port: 7) (Logical Port: 15) (phyId: 1e) Link DOWN.
Feb 4 16:35:10 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 22 could not be found^[[0m
Feb 4 16:35:10 kernel: sched: RT throttling activated
Feb 4 16:35:10 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) (phyId: 8) Link DOWN.
Feb 4 16:35:10 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link DOWN.
Feb 4 16:35:10 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link DOWN.
Feb 4 16:35:10 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Feb 4 16:35:11 kernel: eth5 (Ext switch port: 7) (Logical Port: 15) (phyId: 1e) Link UP at 1000 mbps full duplex
Feb 4 16:35:11 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 22 could not be found^[[0m
Feb 4 16:35:11 avahi-daemon[13859]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Feb 4 16:35:11 wan: finish adding multi routes
Feb 4 16:35:12 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Feb 4 16:35:12 ddns update: ez-ipupdate: starting...
Feb 4 16:35:12 ddns update: asus_private() interface =eth0
Feb 4 16:35:12 ddns update: g_asus_ddns_mode == 2
Feb 4 16:35:13 ddns update: connected to nwsrv-ns1.asus.com (52.250.42.40) on port 443.
Feb 4 16:35:13 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Thu, 04 Feb 2021 15:35:13 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 4 16:35:13 ddns update: retval= 0, ddns_return_code (,200)
Feb 4 16:35:13 ddns update: asusddns_update: 0
Feb 4 16:35:13 ddns: ddns update ok
Feb 4 16:35:13 ddns update: exit_main
Feb 4 16:35:13 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) (phyId: 8) Link UP at 1000 mbps full duplex
Feb 4 16:35:13 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) (phyId: a) Link UP at 1000 mbps full duplex
Feb 4 16:35:13 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
Feb 4 16:35:14 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link UP at 10 mbps half duplex
Feb 4 16:35:15 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link DOWN.
Feb 4 16:35:16 RT-AX88U: start https:8443
Feb 4 16:35:16 RT-AX88U: start httpd:80
Feb 4 16:35:16 httpd: Save SSL certificate...8443
Feb 4 16:35:16 httpd: mssl_cert_key_match : PASS
Feb 4 16:35:16 httpd: Succeed to init SSL certificate...8443
Feb 4 16:35:16 httpd: Succeed to init SSL certificate...80
Feb 4 16:35:17 BWDPI: fun bitmap = 57f
Feb 4 16:35:17 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link UP at 100 mbps full duplex
Feb 4 16:35:18 dhcp client: bound 178.85.113.146/255.255.255.0 via 178.85.113.1 for 135146 seconds.
Feb 4 16:35:21 WAN Connection: WAN was restored.
