RT-AX88U wireless shuts down at irregular intervals
Nighthawke70
ASUSWRT-MERLIN 3004.388.8 Stock, no major setting alterations have been made.
I had recently updated to this version and now my radios shut down at irregular intervals. Just the radios, the LAN stays live. I am forced to do warm reboots or cold boots via the switch in the back of the router. I triple checked to ensure I didn't get the PRO version of the firmware.
Here's the wireless logs post-reboot +2 hours. If you can make heads or tails out of that you are welcome.
SSID: "blackbox 2.4"
noise: -93 dBm Channel: 6
BSSID: D4:5D:64:A0:8B:80 Capability: ESS ShortSlot RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
Chanspec: 2.4GHz channel 6 20MHz (0x1006)
Primary channel: 6
HT Capabilities: 40Mhz SGI20 SGI40
Supported HT MCS : 0-23
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
NSS2 Tx: 0-11 Rx: 0-11
NSS3 Tx: 0-11 Rx: 0-11
Interference Level: Acceptable
Mode : Hybrid
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
C4:39:60:DD:87:EB Yes Yes -66dBm n No Yes Yes No 1 20M 72.2M 72.2M 02:16:43
50:14:79:A4:DD:7C Yes Yes -56dBm n Yes Yes No No 1 20M 72.2M 1M 02:16:44
64:52:99:FA:DF:6F Yes Yes -84dBm n No No No No 1 20M 26M 1M 02:16:52
94:18:65:55:68:D1 Yes Yes -61dBm ac No Yes Yes Yes 2 20M 156M 156M 02:16:53
SSID: "blackbox 5"
noise: -88 dBm Channel: 40/80
BSSID: D4:5D:64:A0:8B:84 Capability: ESS RRM
Supported Rates: [ 6(b) 9 12 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 5GHz channel 42 80MHz (0xe12a)
Primary channel: 40
Supported HT MCS : 0-31
Supported VHT MCS:
NSS4 Tx: 0-11 Rx: 0-11
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : Hybrid
DFS status: state IDLE time elapsed 0ms radar channel cleared by DFS none
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive, Passive
Channel 56 A Band, RADAR Sensitive, Passive
Channel 60 A Band, RADAR Sensitive, Passive
Channel 64 A Band, RADAR Sensitive, Passive
Channel 100 A Band, RADAR Sensitive, Passive
Channel 104 A Band, RADAR Sensitive, Passive
Channel 108 A Band, RADAR Sensitive, Passive
Channel 112 A Band, RADAR Sensitive, Passive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 120 A Band, RADAR Sensitive, Passive
Channel 124 A Band, RADAR Sensitive, Passive
Channel 128 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Channel 144 A Band, RADAR Sensitive, Passive
Channel 149 A Band
Channel 153 A Band
Channel 157 A Band
Channel 161 A Band
Channel 165 A Band
Stations List
BC:30:7D:12:04:2D Yes Yes -61dBm n No Yes No No 2 20M 14.4M 52M 00:45:49
64:17:CD:B4:69:B8 Yes Yes -65dBm ax Yes Yes Yes Yes 2 80M 864.7M 6M 01:33:16
1C:53:F9:18:BD:76 Yes Yes -59dBm ac Yes Yes Yes No 2 80M 780M 433.3M 02:13:41
1C:E6:1D:6C:6A:40 Yes Yes -44dBm ax Yes Yes Yes Yes 2 80M 1201.0M 6M 02:16:35
24:5A:4C:FA:2E:7E Yes Yes -65dBm n No Yes Yes No 2 40M 216M 216M 02:17:44
B0:99:D7:A9:97:5C Yes Yes -67dBm ac No Yes Yes Yes 1 80M 433.3M 351M 02:17:57
38:86:F7:7B:FE:69 Yes Yes -82dBm ac No Yes Yes No 1 80M 325M 65M 02:18:10
94:18:65:55:68:D2 Yes Yes -70dBm ax No Yes Yes Yes 2 80M 612.5M 408.3M 02:18:16
Hmm, a major jump might require resetting to factory defaults before the big hop. I hate to, for i got a ton of static IP assignments and other custom settings that the save does not catch. Pity.
What FW version did you upgrade from ? might be worth trying , can't hurt
