RT-AX89X drops LAN 3&4 when set to VLAN 36
Luc Duguay
Hi I am new here, but been lurking for years.
I have a particular problem with the RT-AX89X. It is a brand new unit, fully reset to factory setting and that came with the latest firmware already installed ( 3.0.0.4.386_22790).
I have the WAN port on 10Gb SFP+ over a fiber connection 1500/940 (Bell Canada). The Copper 10Gb port is connected to a 10G switch.
LAN1 is connected to a GT-AX11000 as an access point for Wifi and 1Gbps Ethernet devices.
LAN4 is on Vlan 36 connected to a IPTV STB.
You can see here that LAN 4 is unplugged!!
When I remove Vlan 36 from LAN4 (or LAN 3), I get the expected 1Gbps connection.
This exact setting works fine on the GT-AX11000, but not on the RT-AX89X.
I tried disabling NAT acceleration to no avail.
Has anyone experienced the same problem?
Thx
