RT-AX92U bootloop
pkozerski
Hello
I need help with my router AX92U, I bought it broken. It has boot loop. Attached logs from UART.
I can enter rescue mode and upload different firmware, I tried 20 different firmwares, original and gnuton, always same behaviour, restart...
Can someone help what can cause this? is it bootloader problem or rather hardware? (CPU/RADIO), in logs there is some kernel panic.
If you have AX92U, can you send me your bootloader/CFE?
Best regards
  • log.txt
Guys, if someone have AX92U, could you send me CFE/bootloader file?
just type in SSH:
cat /dev/mtd10 > misc10.img
cat /dev/mtd9 > misc9.img
cat /dev/mtd8 > misc8.img
and using Winscp for example copy these 3 files somewhere else and send me, thanks in advance!
