RT-AX92U kernel issue reported after firmware upg 3.0.0.4.386_40451
tglesel
I have noticed the following new event (kernel fatal error) in the syslog twice during one week, just after upgrading my RT-AX92Us to 3.0.0.4.386_40451.
Have anyone else experienced this being reported in syslog after new firmware upgrade? I do not experience any connectivity issues and my routers are running fine. However I do not know if this is a a critical event or it can be ignored?
Nov 9 16:33:06 kernel: ifsstat 0xaf ifsstat1 0xff txectl 0x4992 txestat 0x401
Nov 9 16:33:06 kernel: rxestat1 0x4000 rxestat2 0x40 rcv_frmcnt 0x0 rxe_rxcnt 0x16c
Nov 9 16:33:06 kernel: wepctl 0x0
Nov 9 16:33:06 kernel: aqmfifordy 0x0 wepstat 0x0 wep_ivloc 0x1e wep_psdulen 0x166
Nov 9 16:33:06 kernel: PC :
Nov 9 16:33:06 kernel: R0: 0xff8014 0xff8014 0xff8014 0xff8014
Nov 9 16:33:06 kernel: R0: 0xff8c28 0xff8c28 0xff8c28 0xff8c28
Nov 9 16:33:06 kernel: psm stack_status : 0x10
Nov 9 16:33:06 kernel: psm stack_entries:
Nov 9 16:33:06 kernel: 0x00e6
Nov 9 16:33:06 kernel: 0x1472
Nov 9 16:33:06 kernel: 0x11d5
Nov 9 16:33:06 kernel: 0x12c9
Nov 9 16:33:06 kernel: 0x1bfa
Nov 9 16:33:06 kernel: 0x16de
Nov 9 16:33:06 kernel: 0x1ee3
Nov 9 16:33:06 kernel: 0x1fc4
Nov 9 16:33:06 kernel: wl0: fatal error, reinitializing, total count of reinit's[2]
I had a lot of errors in the log when I upgraded my AX-92U router > AP set up.
A simple reboot of both devices cured the problem.
Thanks Andrei. I did manually reboot it one time after upgrade to get AiCloud sync to work again. But I will try one more manual reboot to see if the "kernal fatal error" event in the log will disappear. Was it similar kernal error messages you saw in syslog after upgrade?
I have tried a couple of reboots of my RT-AX92U after firmware upgrade, but the fatal kernel event in still being reported in syslog. I actually noticed that at least one of my devices is disconnected from wifi, when this happens. Anyone experiencing this after upgrade to latest firmware?
Nov 16 17:22:37 kernel: wl0: PSM microcode watchdog fired at 297004 (seconds). Resetting.
Nov 16 17:22:37 kernel: wl0: reason = psm watchdog at 297004 seconds. corerev 42 ucode revision 1570.159 features 0x0426
Nov 16 17:22:37 kernel: psmdebug 0x00ff8014 phydebug 0x0 macctl 0x84160403 maccmd 0x4
Nov 16 17:22:37 kernel: psm_brc 0x0000 psm_brc_1 0x0000 M_UCODE_DBGST 0x2
Nov 16 17:22:37 kernel: brwk_0 0x0080 brwk_1 0x0000 brwk_2 0x0430 brwk_3 0x7101 brwk_4 0x0000
Nov 16 17:22:37 kernel: ifsstat 0xaf ifsstat1 0xff txectl 0x4992 txestat 0x401
Nov 16 17:22:37 kernel: rxestat1 0x4080 rxestat2 0x40 rcv_frmcnt 0x0 rxe_rxcnt 0x16c
Nov 16 17:22:37 kernel: wepctl 0x0
Nov 16 17:22:37 kernel: aqmfifordy 0x10 wepstat 0x0 wep_ivloc 0x1e wep_psdulen 0x166
Nov 16 17:22:37 kernel: PC :
Nov 16 17:22:37 kernel: R0: 0xff8014 0xff8014 0xff8014 0xff8014
Nov 16 17:22:37 kernel: psm stack_status : 0x10
Nov 16 17:22:37 kernel: psm stack_entries:
Nov 16 17:22:37 kernel: 0x00e6
Nov 16 17:22:37 kernel: 0x1472
Nov 16 17:22:37 kernel: wl0: fatal error, reinitializing, total count of reinit's[3]
