RT-BE86U vs RT-AX86U Pro
freddyjuarez
Oh wow I can't wait for the Asus RT BE86U to be released is it me or do y'all think every time Asus announces a new router with that same casing it's not going to disappoint????
I'm hoping they would use that same casing to make a ROG kind
Well I would probably wait and see when it comes out, yes I would get another router myself and yes I will wait for the rt-be92u myself as it supports band 6 and 320 mhz and the one you want only has 160 mhz and uses 5 ghz band,
If you don't need 320 mhz and band 6 on wifi, you can buy the one you're interested in, but if you want another one that has 320 mhz and band 6 ghz, you should get another model if you're looking for what yes rewrote
Hope you think about it before you decide
This new dual-band model will have the same DFS range dependency like your current RT-AX86U Pro. Both use the same bands and will have eventually the same issues in your area.
