RT-BE88U 3006.102.2 - Guest and IoT Networks KO after installing Diversion / Skynet
WillyTP
Hello.
I recently switched an AX-88U Pro with a BE88U.
I'm using latest 3006.102.2_2 firmware.
I configured two networks (Guest plus IoT) and successfully configured them. They were working.
After installing Diversion and Skynet, guest network and IoT one stopped working.
Nevertheless on the router page they were properly "on", there was no signal and obiouvsly no devices could connect.
Removing Diversion and Skynet had no success.
I had to reset everything.
Anybody encountered this issue and / or point me to the issue?
Kind regards
If you haven't done so already, you may want to read through the following discussion topic. May have some additional information or suggestions on using add-on scripts with Asus-Merlin 3006.102.x firmware.
And if you haven't already done so, use the search feature to search this Add-On subforum for "3006". There are a number of pages and topics covering various scripts and the 3006 firmware.
And see the specific topic discussions on the script itself for additional suggestions or ideas. One can "filter" the add-on subforum to show only specific script topics.
