RT-BE88U IPTV - BT TV / EE TV
fka
Has anyone had any luck with IPTV on the BE88U, specifically BT TV (EE TV) in the UK?
I had it working on my AX88U Pro and have tried the same settings on the BE88U with both stock 3.0.0.6.102_33928 and Merlin's 3006.102.2-beta1. The STB connects to the internet but chucks a multicast error when trying to watch 'live' streamed TV.
Settings:
WAN
Enable VPN + DHCP Connection = no
LAN > IPTV
Select ISP Profile = none
Choose IPTV STB Port = none
Use DHCP routes = Microsoft or RFC3442 & Microsoft
Default IGMP version = IGMP v3
Enable Fast Leave = disable
UDP Proxy (Udpxy) = 0
STB is cabled to LAN4. Also tried LAN1 and wireless.
Currently I've had to go back to using the ISP supplied modem.
I have FTTP so the ONT should be dealing with any VLAN ID stuff
