Greetings,
I purchased an Asus RT-BE88U router. The wired throughput is excellent. However, it is only dual band, and I wanted to future proof myself with the third band. I had the option of purchasing the top line ROG quad band, but it has a lot of features I'll never use. I ended up buying a single ZenWiFi BT10. together, they cost less than the TOG quad band, and it gives me an additional broadcaster.
I setup the BT10 as an aiMesh node. So far, so good. Was able to bind clients to one router or the other. One thing though. I can't access the 6Ghz band on the BT10. When I attempt to add a network in the firmware for the RT-BE88U, I get a message saying that would exceed the rules.
My other option is to setup the BT10 as an access point. My understanding is I would be able to use the router's firmware to customize the device.
So, stay with aiMesh and lose the third band, or setup as an access point.
Your guidance would be most appreciated.
Graham
Graham
