RT-BE92U A Mac address I'm Concerned...
freddyjuarez
Im concerned about this Mac address showing up every second on system log if I don't reject it D8:1F:12:97:21:93, I can't match it to any client/device... Like wtf
I want a better solution than just rejecting the Mac address so it doesn't appear on the system log why is it even appearing???
NRAI Services LLC
160 Greentree Drive, Suite 101 Dover DE 19904 US
There was a thread about this a couple of weeks ago. If I remember correctly it’s an IoT device from someplace close by that’s trying to connect to your router over and over again. I have the same logs on my router.
NRAI Services LLC
When I looked up that MAC address, I found that it belongs to "Tuya Smart Inc". I have an IoT device that has that network interface in it, it's an electric. blanket with a wifi interface, very nice *smile*. But this interface could be in any number of IoT devices. So if you can't match it with a device that seems to be missing from your client list, yes, it could be somewhere close enough to be interacting with your router. The way that I usually find these IoT network interface company matches is simply through the good old process of elimination.
Hmmm but what devices are made manufactured that have anything to do with https://nraiservices.com/ cause I don't even know what this company is....
Its a business agent in the state of Delaware where companies incorporate, likely fronting some no-name maker of some cheap IoT device you connected to your secure network. If you can't find it, you can always change your network credentials and reconnect devices until you do.
OE
