RT-BE92U - Guest Pro Network Support?
ExPat
As the title says - Does the RT-BE92U - support Guest Pro Network? I am looking to connect ioT devices to it.
If yes, is there a way to keep the devices on it isolated so that they can only talk to each other and the Internet? Is there a way to add an Ethernet port to this network? I have a Hue Bridge that only has a wired Ethernet connection available.
Thanks in advance.
Thanks in advance.
Should in firmware 3.0.0.6.* It's development-in-progress, so confirm it works as you want. Be sure to reboot the router after changing VLAN associations in the configuration... some configuration changes require a fresh start.
OE
OE
Thank you. It will be fresh out of the box.
Does it also allow the Ethernet ports to be on the guest?
