RT-BE92U observations
JWoo
Have been running the RT-BE92U for a couple weeks. It seems to perform pretty well on all 3 bands with high connect speeds from WIFI7 devices. 6GHz is connecting at 5.7Gbps for example. The router is running firmware 3.0.0.6.102_37504 which just came out on Feb 21. DoT, IPv6 tunneling, guest networks on all 3 bands seem to work well.
When I check the CPU temp using "cat /sys/devices/virtual/thermal/thermal_zone0/temp" from an SSH window, it seems to run between 58 and 60 degrees C. What temp is anyone else seeing?
The memory utilization is around 63%. This is higher than my other Asus routers which run about 50 - 55% memory utilization. I noticed on the latest firmware 3.0.0.6.102_37504 that Asus has a bunch of memory dump commands in the log file. So maybe they are looking into memory leaks?
Your CPU temperature and RAM utilization look normal. There is a long thread with RT-BE92U observations here:
Quite a bit of observations in 14 pages and >250 posts. If you are happy with it - don't poke the settings too much.
I get 61021 from the cmd you posted on be98pro. How should I read it? is it 61c?
