Has anyone updated to this new (as of today: 12-18-2012) firmware?
I am still running 1.0.1.8N due to some issues that I have heard about relating to the 3.0.0.4.260 firmware.
I'm not certain if you need to do the reset after the upgrade, as Asus recommended with the 3.0.0.4.260 firmware update. If I end up performing the update, I'll save current settings and post the results here.
Hi Everybody!
Please try out version .318 and let me know if you have any problems. This version has updated wireless drivers that should fix many of the wireless disconnections experienced with previous versions.
Version 3.0.0.4.318
Thanks!
P.S. @RogerSC: Please contact me with the issues you are having with IPv6.
Only found some graphic issues....
The QOS Screen overlaps the help/search area.
SSID Should be lowered down allow more characters. (would make the interface look better and there's plenty of room).
Included is a photo of what im refering to...
http://imageshack.us/photo/my-images/23/318graphicerrors.jpg/
Some have inquired as to a "guest mode" on the 56U and it is still not offered as an option with the .318 update.
Also, has anyone found it necessary or not to do a factory reset on the router after the upgrade to .318? Thanks!
Seems functional except for IPv6 looking broken.
6to4 does not work.
any dns wont work, only connect automatically works. minidlna also having problem sometimes. restart by itself while watching videos. Should have some options or tweaks on it. .317 seems to be much much much better.
Thread starter | Title | Forum | Replies | Date |
A | Can't recover my RT-N56U | ASUS N Routers & Adapters | 0 |
Welcome To SNBForums
