RT-N66U and SD Cards
ecnav
I've searched but I couldn't find a definite answer.
I have an SD card reader with an SDHC card attached to the RT-N66U for the FTP server. I was thinking of upgrading to the SDXC 64GB card. Will the RT-N66U be able to read SDXC cards before I drop money to purchase one?
Thanks in advance.
Why not use MicroSD with the internal MicroSD slot, or go with a standard USB flash drive, or a USB HDD?
I have read that the internal MicroSD supports 64GB.
If you are using a card reader connected to the router, then I think the card reader needs to support SDXC, not the router. The router only needs to support the card reader.
Or maybe I am just confused. :)
